Results 1 to 8 of 8
    Senior Member
    AutoCAD 2006
    Jan 2008
    286
    Default How to maintain dimension style
    Hello: I'd like to set my dimension style so that it will remain the same all the time.
    Here's what I'm doing so far:
    Click Format menu--> Dimension style-->pick dimension that will be changed.
    Choose Modify--> click text--> then insert text height. Click to set current.
    When I do this, it works till I close my drawing; however, when I re-open Cad, I have to do this all over again. How can I retain my settings?
    Thanks for your help,
    Proctor
    ps...I'm using Autocad mechanical 09
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Are you using a custom template or are you using the built-in default template?
    Are you saying it is changing in a particular file - or when you start a new file?
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Senior Member
    AutoCAD 2006
    Jan 2008
    286
    Hello: I'm using the built-in default template.
    Proctor
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    Proctor, when you make changes to the Dimension Style, you're only changing it for that drawing. In order for those settings to be retained when you start a new drawing, you have to save the drawing as a template. You can also import your custom dimension styles from another drawing with Design Center (as long as the Dimstyle has a different name than those that already exist in the target drawing)
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    For your consideration and building on what nestly said you might want to create a custom template with all your layers, linetypes, dimension styles, text styles, system variables, etc. and use it whenever you start a new drawing. Think of the time you'll save. You'll amaze your co-workers and your boss will think you're a genius, give you a promotion and a big raise to boot!
  6. #6
    Senior Member
    AutoCAD 2006
    Jan 2008
    286
    Thank you for your suggestions. As suggested, I built a custom template to use when I start a new drawing.....and everything's working great now!!
    Thanks again,
    Proctor
  7. #7
    Super Member
    Intel DG33FB
    4GB DDR2 6400
    ATI Firepro 5800
    AutoCAD 2011
    Sep 2010
    1,895
    Imagine how wealthy you'd be if you got a percentage of all the added productivity resulting from your help/tips.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    But I am wealthy. Look at all the people I have gotten to meet and interact with, like yourself, over the past 6 years. Priceless.
  1. Dimnsion style changes without dimension style being changed
    By Epicurwin in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 27th May 2011, 01:52 am
  2. Dimension height grayed out in Dimension Style Manager
    By eklektikus in forum AutoCAD Beginners' Area
    Last Post: 14th Oct 2010, 04:37 pm
  3. Dimension Style
    By UMRVJX in forum AutoCAD General
    Last Post: 30th Jun 2010, 06:48 pm
  4. AutoCAD 2006 - how to make dimension m and cm in one dimension style
    By sokha in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Sep 2009, 08:45 am
  5. Dimension>Style or Format>Dimension Style problem
    By jocaan in forum AutoCAD Beginners' Area
    Last Post: 21st Apr 2004, 08:50 pm
