Exclamation Triangle After Exiting Autocad 2011 and 2012
Lizardman
I open files from many different customers in 'vanilla' Autocad 2012, upon exiting I occasionally get an exclamation mark inside of a triangle that appears on the screen by itself after the program closes...No text associated with the close just an exclamation mark inside of a triangle with an 'OK' to dismiss....Does not appear to be file specific, does not happen after any specific input either...Is there perhaps a log I can enable and/or interrogate to see what is causing this warning?
Thanks in advance for any clues as to what may be causing this mystery warning!:geek:
