Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2007
    Aug 2011
    2
    Default Trim selection & Object selection problem
    I have recently run into a problem when I try to trim or select objects to delete. When I selct one object and then go to the next the first object de-selects. Any help would be appreciated
    Super Member qball's Avatar
    Structural
    qball's Discipline Details
    Structural
    Structural / Architectural, Residential, Multi-family, Industrial, Wood frame, Steel, Masonry, Concrete, Tilt-up
    AutoCAD LT 2018
    Feb 2007
    Kelowna, Canada
    741
    turn PICKADD to 1 or 2. If you didn't knowingly change it yourself, some Lisp programs change that kind of thing, or so I've heard.
    I don't have a catchy signature
    Forum Newbie
    AutoCAD 2007
    Aug 2011
    2
    Thanks for the help. I ended up re-installing and that has seemed to correct the problem. I'll keep your advise for future reference.
  1. Replies: 1
    Last Post: 18th Nov 2010, 01:56 pm
  2. Problem with object selection
    By dinarele in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Jun 2010, 03:21 pm
  3. object selection
    By salman in forum AutoCAD General
    Last Post: 2nd Feb 2010, 10:18 am
  4. Object selection
    By Tekenmeester in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Jan 2010, 07:45 am
  5. help with object selection
    By S.T.A.R.S.MEMBER in forum AutoCAD Drawing Management & Output
    Last Post: 29th Mar 2006, 12:02 am
