Results 1 to 2 of 2
    Senior Member ketxu's Avatar
    ketxu's Computer Details
    Sorry, my English not well :(
    AutoCAD 2007
    Sep 2010
    169
    Question [Help] How can i decide which Vlr do in runtime ?
    Hi All
    Please help me a problem.
    I have some reactor function in one file.
    The first time load lisp, i will decided which reactor to used follow a variable (call x) like :
    Code:
    (cond
        ((= x 1)(setq Reactor-Put1 (vlr-editor-reactor nil '((:vlr-commandended . Function1)))))
        ((= x 2)(setq Reactor-Put2 (vlr-editor-reactor nil '((:vlr-commandended . Function2)))))
        ((= x 3)(setq Reactor-Put3 (vlr-editor-reactor nil '((:vlr-commandended . Function3)))))
    But value of x can be changed later when user choice other method (by a dialog). how can i watching x value to decided what to do next ?
    Ex : default value of x is store in registry as 1. So the first time it will call function1 reactor. But then user change it value to 2. How can i run actor function2 and remove vlr funtion1
    Have i make a temple function to call ?
    Thanks all for reading
    Senior Member
    JohnM's Computer Details
    xp pro
    AutoCAD 2006
    Feb 2009
    houston, texas
    380
    Have a look at the vlr function list there are a few functions to deal with reactors
    Vlr-remove & vlr-reactors.
    When dealing with reactors it’s a good idea to check and see if a reactor is loaded before calling it again.
    If you call it twice there will be 2 instances of the reactor running
    So in your cond statement you can use (if (not reactor-put1 (setq reactor-put1…………..
    So if the user selects another reactor you need to unload the current one using
    (if reactor-put1(vlr-remove reactor-put1))
    From my experience reactors are hard to debug so you only want to load then once and remove them when done unless you want them to be persistent.
  1. runtime error 94
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jul 2009, 09:15 am
  2. Help decide the future at AUGI
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 23rd Jan 2009, 05:00 pm
  3. LT 2009 with Subscription or eBay LT 2008 ?? Please help decide.
    By Jez(UK) in forum Software & Licensing
    Last Post: 23rd Jan 2009, 01:06 pm
  4. .net Runtime error
    By PhUzZ in forum AutoCAD Drawing Management & Output
    Last Post: 26th Apr 2006, 01:24 pm
