kabcad; I haven't tested your routine, but it sounds an awful lot like you need to change a setting in your drawing ATTDIA to be 1, that same thing happens to me in 2002 when my dialog boxes are suppressed by that variable. When ATTDIA is set to 0, you have to manually enter your block attributes at the prompt. (I didn't double check the name of the attribute dialogue variable, I don't have time, but you can dig for it if I got the wrong one.). Good luck.
