CADgirl Posted August 18, 2011 Share Posted August 18, 2011 I don't know what is going on with my AutoCAD. I got on today and there are a couple things that are messed up. One thing is my right click menu. I right clicked on the viewport to lock it and the option wasn't even there. I had to go to properties and change it from there. And there are a few other things missing from it too. Also, it won't let me select something and then type in the command. For example, alot of times I select an object and then type in E (for erase) and then enter. (I would create a seperate thread for this problem but I have no idea where to post it.) Any tips or ideas on why this is happening would be great! Thanks!! Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 18, 2011 Share Posted August 18, 2011 I don't know what is going on with my AutoCAD. I got on today and there are a couple things that are messed up. One thing is my right click menu. I right clicked on the viewport to lock it and the option wasn't even there. I had to go to properties and change it from there. Options > User Preferences tab > Right-click Customization button And there are a few other things missing from it too. Also, it won't let me select something and then type in the command. For example, alot of times I select an object and then type in E (for erase) and then enter. Sounds like PICKFIRST = 0, try setting PICKFIRST = 1 (I would create a seperate thread for this problem but I have no idea where to post it.) Meh - don't worry about it (this time!) LoL Quote Link to comment Share on other sites More sharing options...
nestly Posted August 19, 2011 Share Posted August 19, 2011 I believe PICKFIRST=1 is the solution for both. Quote Link to comment Share on other sites More sharing options...
CADgirl Posted August 23, 2011 Author Share Posted August 23, 2011 Pickfirst solved the problem. Thanks so much! Quote Link to comment Share on other sites More sharing options...
BlackBox Posted August 23, 2011 Share Posted August 23, 2011 Pickfirst solved the problem. Thanks so much! ... Quote Link to comment Share on other sites More sharing options...
