Results 1 to 9 of 9
    Full Member DonovanPorter's Avatar
    DonovanPorter's Computer Details
    Windows & 64 bit
    Celsius M470-2
    Xeon E5630
    2.53GHz 12mb
    16 gig
    NVIDIA Quadro FX1800
    1 TB
    1 TB
    2 x 20" Acer
    Civil
    DonovanPorter's Discipline Details
    Water Infrastructure
    Civil
    Civil 3D 2011
    Aug 2009
    South Africa
    51
    Default Fillet acting strange
    morning guys and gals
    experiancing this issue
    when using the fillet command on two lines that are at a 90° to each other , radius set to zero , it will just connect the 2 lines , by extending the one line to the other but it changes the angle of the one line , if that makes sense ?
    ill try post a picture
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,137
    How is that even possible? Are you positive the two lines are 90 deg to each other to begin with?
    Windows & 64 bit
    Celsius M470-2
    Xeon E5630
    2.53GHz 12mb
    16 gig
    1 TB
    1 TB
    2 x 20" Acer
    Civil
    Civil
    Civil 3D 2011
    Aug 2009
    South Africa
    51
    100% sure it was very strange , it was constantlydoingit , i rebooted and it came right and i could not reproduce the issue , very strange
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,137
    So this was something you were seeing on your screen but you did not confirm it in any manner?
    Did the line that appeared to no longer be correct look jagged?
  5. #5
    Windows & 64 bit
    Celsius M470-2
    Xeon E5630
    2.53GHz 12mb
    16 gig
    1 TB
    1 TB
    2 x 20" Acer
    Civil
    Civil
    Civil 3D 2011
    Aug 2009
    South Africa
    51
    it was jagged i confirmed that it was incorrect , the measurement was incorrect as well as the angel
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,137
    The angle and the measurement of the line both changed when you used the fillet command. I can understand the length changing if the two lines you filleted were separated by a gap but the angle changing I don't understand. Now you say it self-corrected after a reboot. That's even more bizarre. Has this happened before? Where did you get this drawing?
  7. #7
    Windows & 64 bit
    Celsius M470-2
    Xeon E5630
    2.53GHz 12mb
    16 gig
    1 TB
    1 TB
    2 x 20" Acer
    Civil
    Civil
    Civil 3D 2011
    Aug 2009
    South Africa
    51
    yip the angle changed very bizzare , this drawing was from scratch , construction lines were used trimmed etc to get the lines iam working with , after the reboot all was great and the fillet command was as new. this has never happened before .
    i must add this is on a new pc of about a week old and there seems to be a few software glitches , with regards to the custom ribbons lisps incorporated into our templates. i have spoken to the person who created the template and he is not to sure what the cause may be.
    but after the reboot all is good , if i get any feed back or a cause of this ill defiantly post it here.
  8. #8
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,005
    Seems that OP isn't the first one that encountered this.
    Regards,
    Mircea
  9. #9
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    Quote Originally Posted by msasu View Post
    Regards,
    Mircea
    Ditto, I saw this problem over at the Autodesk forums earlier this year, and as far as I know, it's still unresolved.
    http://www.screencast.com/t/xta1fID3bo
  1. Strange problem in FILLET command in AutoCAD 2011
    By archash in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 29th Jul 2010, 05:15 pm
  2. MEP's ..acting strange
    By Tiger in forum MEP
    Last Post: 21st May 2008, 12:05 pm
  3. Confused? Blocks acting strange
    By steepcreeker in forum AutoCAD Drawing Management & Output
    Last Post: 2nd May 2007, 06:48 am
  4. Polyline Acting Up
    By Jamalama in forum AutoCAD Drawing Management & Output
    Last Post: 14th Dec 2006, 11:33 pm
