Additems to activeselectionset
Lt Dan's legs
what am I doing wrong?
(setq test1
 (vlax-safearray-fill
   (vlax-make-safearray vlax-VBobject (cons 0 0))
   (list (vlax-ename->vla-object (car (entsel))))
(setq test2
 (vlax-make-variant test1)
;;both of these will not add an item to the activeselectionset
;test1
(vla-additems (vla-get-activeselectionset *acdoc*) test1)
;test2
(vla-additems (vla-get-activeselectionset *acdoc*) test2)
Aside from the personal challenge aspect, may I ask why go through all of the extra work?
Admittedly, I am not so good when it comes to SafeArrays, Variants, and the like - That's why I love using vlax-3d-point! LoL
Anyways, I ask because it seems simpler to just use SSADD, for example:
(defun c:FOO ()
 ((lambda (acDoc)
    (vla-startundomark acDoc)
    (vlax-for x (vla-get-activeselectionset acDoc)
      (vla-put-color x acred))
    (vla-endundomark acDoc))
   (vla-get-activedocument (vlax-get-acad-object)))
 (princ))
(defun E->SS (e ss) (ssadd e ss))
(defun c:E2SS ()
 (sssetfirst nil (E->SS (car (entsel)) ss))
 (princ))
(setq ss (ssget))
Use that last line to make an initial selection set (global var "ss" for this example), then run E2SS multiple times.
Edit: FOO will just turn the items in the (current) selection set red, undo to run E2SS again, and see the changes.
This works for me:
(defun c:test ( / acdoc acsel acutl obj )
   (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
         acutl (vla-get-utility acdoc)
   (if (ssget)
           (setq acsel (vla-get-activeselectionset acdoc))
           (princ (strcat "\nSelSet Count: " (itoa (vla-get-count acsel))))
           (while
               (not
                   (vl-catch-all-error-p
                       (vl-catch-all-apply 'vla-getentity
                           (list acutl 'obj 'pnt "\nSelect Object to Add: ")
               (vla-additems acsel
                   (vlax-make-variant
                           (vlax-make-safearray vlax-vbobject '(0 . 0)) (list obj)
Note that entsel/vlax-ename->vla-object could be used, but I wanted to mix things up :playing:
I happened to notice additems in the method section when
(vlax-dump-object (vlax-get (vlax-get (vlax-get-acad-object) 'ActiveDocument) 'Activeselectionset) t)
I just wanted to try it. It really bugs me when I can't get something to work.
Great Scott! He's gone Vital LISP on us!?!? :o:P
This works for me:
<snip>
Cool Lee - I couldn't get it (my version) to work when I was putting one together before posting the ssadd bit. But I did notice the options and paused on vlax-vbobject. It's nice to see a working example of something you struggle with figuring out. It really helps with the learning process. :beer:
