Results 1 to 8 of 8
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Default Diameter symbol for Excel export
    I’m exporting some data from AutoCAD to an Excel file by AutoLISP code. Since I need the diameter symbol along with other exported data I have generated it by <Alt>+0216 and pasted in code. When the Excel is exported on one workstation it isn’t rendered correctly – it appear like an “r” character instead. However the user of that station say that he use the same above combination of keys when need to write the symbol.
    Does someone know a solution for this? Thank you!
    Regards,
    Mircea
    Senior Member LibertyOne's Avatar
    AutoCAD 2010
    Apr 2011
    Germany
    194
    Try using <ALT>+0248 instead and test it to see if you get better results.
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Thank you for your answer - I will try it.
    Regards,
    Mircea
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,177
    <Alt>+0216 and <ALT>+0248 are the same if the default language is English, but if not , the symbol would be different .
  5. #5
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    What realy confuse me is that <Alt>+0216 had the same result both on my and his workstation – the difference appear only when the character is generated programmatically.
    Regards,
    Mircea
  6. #6
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,177
    I think because there is not Alt press while exporting data or strings to Excel sheet .
  7. #7
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,535
    Maybe:
    Code:
    (chr 248)  =  "ø"
    (chr 216)  =  "Ø"
    (print "\370")  =  "ø"
    (print "\330")  =  "Ø"
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  8. #8
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Sorry for my delayed answer, but I had to wait for my pal to check this on his trouble-maker workstation. Unfortunately, none of the above suggested solutions have worked – the diameter symbol is still wrong displayed.
    I really don’t know what to do on this matter...
    Thank you again for your support.
    Regards,
    Mircea
  1. export dwg to excel
    By SK in forum AutoCAD Beginners' Area
    Last Post: 25th Feb 2016, 07:34 pm
  2. How to remove the diameter symbol?
    By GeeN in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Jan 2015, 12:48 am
  3. Export to Excel
    By blotty in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jan 2011, 07:26 am
  4. Find/Replace not recognizing diameter symbol
    By EnderM3 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Aug 2010, 01:40 pm
  5. get rid of diameter symbol with out exploding?
    By Ed G in forum AutoCAD Drawing Management & Output
    Last Post: 14th Sep 2005, 08:10 pm
