Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,796
    Quote Originally Posted by AutoSaint View Post
    No, I am not. I will browse on the net, however bare in mind that this building rises at 15 meters, so I don't know if they can support all this floors as my intention is that the walls are also the supporting structure as I am not familiar with this technique.
    About the window, there will be aluminium frame, but I was hoping to not have any frames on the corner.
    something like this: http://i55.tinypic.com/ofy9tz.jpg
    Nice lookin' window, I wouldn't want a corner blocking the view either.
    Thinkin', "Solid concrete? Why not a 90° "I" beam header?"
    The header could bolt corner to corner or, welded at a 90° angle.
    The steel header would be sized to support any weight from above.
    The steel header would be encapsulated in concrete.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  2. #12
    Forum Deity Jack_O'neill's Avatar
    Jack_O'neill's Computer Details
    xp
    Architectural
    Jack_O'neill's Discipline Details
    Architectural
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    AutoCAD 2010
    Sep 2008
    lost in the Arkansas wilderness
    2,146
    Most commercial curtain wall companies will try to talk you out of not having a framing member in the corner like that. For one reason, it is extremely difficult to make such a corner weather tight. Depending on the size of the window, framing will be necessary structurally. Glass is not a structural component, and the movements of the building due to wind, seismic activity, and weather (solar heating) must be accounted for. In the detail below, you see a single framing member shown. That minimizes the intrusion into the view, yet provides the structural stability required. I suggest you visit some of the websites for companies like Kawneer and VistaWall for ideas. They have many examples and construction details available for download.
    It is possible to do your corner, but the window will be limited in size. It will be up to the structural engineer to figure out just how big your opening can be.
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
  3. #13
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,042
    I have moved to the Student Project Questions sub-forum.
  4. #14
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Your wall is almost a foot thick
    I thought he meant the conc. slab was 300 think (which is fairly common)?
    Concrete block walls have been used for decades and 15 meters really doesn't seem that high.
    It is still fairly high. Wind actions would start to become a factor given I imagine the structure would be a lot longer than it is wide. You'd really need a structural steel frame in my opinion, in which it would not be a problem to offset suitably sized columns from the building corner (to allow for the corner window opening).
  1. painted concrete
    By rookie37 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Nov 2009, 11:29 am
  2. Replies: 0
    Last Post: 14th Jul 2009, 08:53 am
  3. concrete hatch
    By richjamesw in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jan 2008, 04:16 pm
  4. Corner but using a crossing window selection
    By James in forum AutoCAD General
    Last Post: 1st Nov 2007, 12:34 pm
  5. corner window?
    By nivradolobo in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Oct 2007, 05:27 pm
Tags for this Thread
