Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    Full Member
    Tony D's Computer Details
    Windows 7, Home Premium, 64 bit
    HP TouchSmart 300 1330
    Pegatron, APP78-CF
    AMD Athlon II X2 240e
    4 GB
    Integrated ATI Radeon HD3200, shares memory with system
    ST350041 8AS SATA 500 GB
    4.7 GB
    This is an HP Al-in-One Computer 300 1330, I have another monitor which is a Sceptre.
    AutoCAD 2011
    Jul 2011
    Sahuarita, AZ
    31
    Default Filleting
    I am having a problem filleting two circles. the drawing was done using 2D polyline per instructions from worldclass.com wesite. I have attached a copy of the drawing, and the drawing has two red arrows pointing to the circles in question. The radius of the fillet is supposed to be .5".
    Tony
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,725
    Why not do that as 3D rather than fool with wireframe?
    I once took an idiot exam that required that I do something like this as wireframe.
    I simply did as 3D and exploded to 2D wireframe.
    Increased my income by several thousand dollars by passing the "competency" exam.
    The proctor never new the difference.
    Forum Deity Jack_O'neill's Avatar
    Jack_O'neill's Computer Details
    xp
    Architectural
    Jack_O'neill's Discipline Details
    Architectural
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    AutoCAD 2010
    Sep 2008
    lost in the Arkansas wilderness
    2,146
    Quote Originally Posted by Tony D View Post
    Attachment 29633
    Tony
    Something doesn't look quite right. Are you trying to fillet between the 2 circles? If so, why? This appears to be some sort of housing with a bushing pressed into it. You have 3 concentric circles, so I presume the small one in the center is a hole, the next one is the outer edge of the part with the hole in it, and the outer most circle is the edge of the housing. See the illustration below.
    Or are you trying to fillet the edges like this?
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
    Full Member
    Pegatron, APP78-CF
    4 GB
    4.7 GB
    AutoCAD 2011
    Jul 2011
    Sahuarita, AZ
    31
    scan0001.pdfTo Jack_O'neill,
    Quote Originally Posted by Jack_O'neill View Post
    See the attached copy of the drawing (note where the two red arrows are pointing to), it may help you to know what I am trying to convey, below:
    Tony
    Last edited by Tony D; 26th Aug 2011 at 01:23 am. Reason: A sentence was not worded correctly
  5. #5
    Full Member
    Pegatron, APP78-CF
    4 GB
    4.7 GB
    AutoCAD 2011
    Jul 2011
    Sahuarita, AZ
    31
    To: JD Mather,
    Quote Originally Posted by JD Mather View Post
    To answer your question the Instructor wants us to do the drawing using polylines. He has never mentioned anything about doing the drawing in 3D. Is it much more simpler to do it in 3D?
    Tony
  6. #6
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    Ah, I see. That makes more sense. You should have mentioned that you were trying to draw a weld. In the images below, you'll see solid models, a wire frame view and a hidden view. I gave you the front, back and a cross section. On the back view, I pulled the round part up half way in the plate to have something to fillet to. If it needs to be flush, we'll have to do some more work with the shape of the inserted piece, but I think you can probably figure that out. If not, give a yell.
  7. #7
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    To: JD Mather,
    Tony
    Not that I would speak for JD, but absofrackinlutely! The images you see in my previous post took about 5 minutes to create.
  8. #8
    Full Member
    Pegatron, APP78-CF
    4 GB
    4.7 GB
    AutoCAD 2011
    Jul 2011
    Sahuarita, AZ
    31
    To: Jack_O'neill,
    Here is a copy of the drawing from the PDF document. You can see where he wants the fillet.
  9. #9
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    Ah yes, that makes much more sense. If I may, you have a small error in your drawing according to this. Notice the small hole in the center? You have it drawn as coming all the way to the end of the large round bit. It actually only penetrates the square plate. That's why you were having such a hard time figuring out what to do and it threw my drawing off as well. The red bit in those last images is not there. What want it to look like is this:
    Your instructor is making you do this the hard way huh? Even the page you uploaded says something about using this "solid". I wonder why he's going to such lengths.
  10. #10
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,947
    The 1/2" Fillet (the T is pronounced) weld should be done with chamfer not a fillet.
    I looked closer and see that chamfer is called out for all of the holes as well.
    What course/school is this? I will move this to the Student Project Questions sub-forum.
  1. Dimensions on a isometric circle
    By 30144683 in forum AutoCAD Beginners' Area
    Last Post: 18th Jan 2011, 04:51 am
  2. View Isometric 3D and Its 2D Views( Top, Elevation and front View) !!
    By basiony in forum AutoCAD Beginners' Area
    Last Post: 7th Dec 2010, 04:22 pm
  3. Dimensioning in isometric
    By Wilbri in forum AutoCAD Beginners' Area
    Last Post: 14th May 2010, 09:24 am
  4. isometric align dimensioning
    By bdr2k5 in forum AutoCAD Beginners' Area
    Last Post: 27th Apr 2010, 06:35 pm
  5. Circle-Isometric Snap
    By Shibuboss in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Aug 2009, 01:41 am
