Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
  1. #21
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    I have merged your two threads. They are both covering the same topic.
  2. #22
    Full Member
    Tony D's Computer Details
    Windows 7, Home Premium, 64 bit
    HP TouchSmart 300 1330
    Pegatron, APP78-CF
    AMD Athlon II X2 240e
    4 GB
    Integrated ATI Radeon HD3200, shares memory with system
    ST350041 8AS SATA 500 GB
    4.7 GB
    This is an HP Al-in-One Computer 300 1330, I have another monitor which is a Sceptre.
    AutoCAD 2011
    Jul 2011
    Sahuarita, AZ
    31
    Default Missing Information on a Drawing
    I have a few questions in regards to the attached image.
    1.) - Where you see the red arrow pointing to how do I get a 1/16 x 45 degrees chamfer for the four holes?
    2.) - Same as question 1.) (Where the green arrow is pointing to). Only this relates to the 4" diameter circle.
    3.) - I don't know how I determine what the radius/diameter is supposed to be. Is there a way you can determine the radius/diameter without any note(s)?
    4.) - Where the magenta arrow is pointing to I think someone in the forum said that it should be a chamfer, not a fillet as worded on the image. Is that right? Also, looks like you have to pick the bottom of the 4" circle and the plate, am I correct, or what?
    What I don't understand is that I never got any tutoring on filletting/chamfering,
    on circles, matter of fact on any object. Also no mention of determining the radius/diameter of a circle without any note(s).
    5.) - In the drawing it does not stipulate what the height of the 3 & 4 Inch circles should be. So, how do you determine what the height should be?
    Tony
    Edit Post Reply Reply With Quote
  3. #23
    IBM Lenovo
    ACPI x64
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    Why do you keep starting new threads on the same subject?
    1. _CHAMFER>D>1/16>1/16> select the top edge of hole.
    2. See #1, though the chamfer is only for the inside 3" diameter.
    3. Radius/Diameter of what?
    4. Yes
    5. You cannot.
    Threads merged.
  1. Dimensions on a isometric circle
    By 30144683 in forum AutoCAD Beginners' Area
    Last Post: 18th Jan 2011, 04:51 am
  2. View Isometric 3D and Its 2D Views( Top, Elevation and front View) !!
    By basiony in forum AutoCAD Beginners' Area
    Last Post: 7th Dec 2010, 04:22 pm
  3. Dimensioning in isometric
    By Wilbri in forum AutoCAD Beginners' Area
    Last Post: 14th May 2010, 09:24 am
  4. isometric align dimensioning
    By bdr2k5 in forum AutoCAD Beginners' Area
    Last Post: 27th Apr 2010, 06:35 pm
  5. Circle-Isometric Snap
    By Shibuboss in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Aug 2009, 01:41 am
