Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Full Member
    Civil 3D 2011
    Aug 2011
    99
    Default Scaling Polyline Contours
    I have a great request. I need to scale some polyline contours from ground to grid coordinates. Using the scale comand this works, but the Z value is scaled as well. The thing is, I want to scale the X and Y only, not the Z.
    So far the only way to do this is to create a block, scale it, then explode. This takes a lot of time that to me seems unnecessary.
    So this is what I was thinking for a lisp routine that can do what I need.
    Select a polyline (contours)
    Scale the polyine to some factor.
    Reset the Z value to the orginal value before scaling.
    I hope this makes sense. Haha.
    Anyone willing to tackle this?
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,968
    Quote Originally Posted by Bill_Myron View Post
    If you scale the contours individually, then the Z value is not scaled.
    Most people would probably scale the coordinates before they entered the data.
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,948
    Look into vla-scaleEntity function.
    "Potential has a shelf life." - Margaret Atwood
    Full Member
    Civil 3D 2011
    Aug 2011
    99
    eldon - The scale command scales the polyline uniformly. It applys the scale to all 3 axis. The data that was given to me was just the contour polylines. Therefore i can only use what was given.
    Render man - Thanks for the start. Can this lisp be manipulated to only scale in the x and y directions and not the Z?
  5. #5
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,641
    Scaling contours like that is not a good practice in my opinion.
    If this works and you only need to do it one off then why not just do this?
  6. #6
    Civil 3D 2011
    Nov 2009
    3,948
    What results did you get in your code testing?
  7. #7
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,968
    Only if you scale about 0,0. If you scale each individual contour polyline about its own endpoint, the Z value is unaltered.
  8. #8
    Senior Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2012
    Feb 2010
    Belgrade, Serbia, Europe
    332
    Code:
    (defun c:scpl ( / pt elev bpt entpl scf )
      (setq pt (getpoint "\nPick base point in XY plane for scaling your pline : "))
      (setq entpl (car (entsel "\nPick pline you want to scale")))
      (setq elev (cdr (assoc 38 (entget entpl))))
      (setq bpt (list (car pt) (cadr pt) elev))
      (setq scf (getreal "\nInput scale factor with or without decimal precision : "))
      (vl-cmdf "_.scale" entpl "" bpt scf)
    M.R.
  9. #9
    Civil 3D 2011
    Nov 2009
    3,948
    Quote Originally Posted by marko_ribar View Post
    Code:
    M.R.
    I hope the user doesn't miss...
  10. #10
    Civil 3D 2011
    Nov 2009
    3,948
    Slight revision to Marko's code (hope you don't mind):
    Code:
    (defun c:SCPL  () (c:ScalePlines))
    (defun c:ScalePlines  (/ *error* nomutt oldNomutt ss pt scale)
      (princ "\rSCALE MULTIPLE POLYLINES ")
      (vl-load-com)
      (defun *error*  (msg)
        (and oldNomutt (setvar 'nomutt oldNomutt))
        (if acDoc (vla-endundomark acDoc))
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** "))))                 ; Fatal error, display it
        (princ))
      (defun nomutt (arg)
        (cond (oldNomutt)
              ((setq oldNomutt (getvar 'nomutt))))
        (if arg
          (setvar 'nomutt 1)
          (setvar 'nomutt 0)))
      (prompt "\nSelect multiple polylines to scale: ")
      (if (and (nomutt T)
               (setq ss (ssget "_:L" '((0 . "LWPOLYLINE"))))
               (nomutt nil)
               (setq pt (getpoint "\nSpecify base point: "))
               (setq scale (getreal "\nEnter scale factor: ")))
        ((lambda (acDoc / elev)
           (vla-startundomark acDoc)
           (vlax-for x  (setq ss (vla-get-activeselectionset acDoc))
             (setq elev (vla-get-elevation x))
             (vla-scaleentity x (vlax-3d-point pt) scale)
             (vla-put-elevation x elev))
           (vla-delete ss)
          (vla-get-activedocument (vlax-get-acad-object)))
        (cond (pt (prompt "\n** Scale factor required ** "))
              (ss (prompt "\n** Base point required ** "))
              ((prompt "\n** Nothing selected ** "))))
      (princ))
    Last edited by BlackBox; 30th Aug 2011 at 06:19 pm. Reason: Revised code to allow selectionset, limit to LW*
  1. Scaling a polyline based on its area
    By harilalmn in forum AutoCAD General
    Last Post: 12th Jan 2011, 12:34 pm
  2. Contours
    By waqashraf in forum AutoCAD Beginners' Area
    Last Post: 17th May 2009, 05:11 am
  3. PLEASE HELP! Contours
    By skills12345 in forum Civil 3D & LDD
    Last Post: 21st Oct 2008, 03:05 pm
  4. Contours to 3ds max
    By almunro in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Feb 2007, 11:53 pm
  5. contours
    By sharma in forum AutoCAD General
    Last Post: 3rd Feb 2005, 09:31 pm
Tags for this Thread
