Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Full Member
    AutoCAD LT 2012
    Aug 2011
    79
    Default I need to clear span the garage, any cad details out there?
    Hey to everybody;
    Over the years I used laminate beams when I needed to clear span space in residential homes, especially garages and great rooms. I been out of it for a long time now so my question is this, what's the latest thing going to clear span a garage or great room area? the span is 24'-6" to outside walls. To add insult to injury I have 16' feet over the garage that will be floored for future living space.
    Anybody up on the latest greatest and where can I find the cad details for this little project.
    Thanks in advance.
    James
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    One option you can use is Parallam® parallel strand lumber (PSL) beams.
    http://www.ilevel.com/floors/f_ParallamPSL_beams.aspx
    Another might be the use of a wood "I" joist.
    http://i-joist.org/
    Senior Member
    nicolas's Computer Details
    Windows 7
    Intel Dual Core 64 Bits
    2 GB
    AutoCAD 2012
    Jan 2008
    Port Louis, Republic of Mauritius
    332
    Here we need an engineer certification for an effective span exceeding 5m. Now you are talking about an 8m span + additional spaces above. Answers to your post will be indeed interesting. I am personally looking for tables depicting span|sectional area of concrete|sectional area of steel for T-Beam, Columns and Slab. I am also working on RC Beam details and as soon as I have enough info I will post preliminary works here for discussion.
    So far I know, the greater the span and the load, the greater the concrete section and If we want to limit oversize sections, we increase area of tensile and compression steel reinforcement as well as shear reinforcement in terms of stirrups. I remember reading in a Design book about opting for the concrete as design basis, for the thought expressed was that the concrete needs to crack for the steel to start working and this is not recommended. I don't know the truthfulness of this or perhaps it's misread.
    A book that puts everything together in contrast to so much pluralism and myths will be most welcomed.
    Regards,
    Nicolas.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    You might look into the use of a steel beam. We used a W16x36 to clear span 40' as part of a pipe rack.
  5. #5
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    TJI is what everyone around here uses for engineered wood floor joists.
    http://www.ilevel.com/floors/f_TJI_joists.aspx
  6. #6
    Full Member emwhite's Avatar
    emwhite's Computer Details
    Win 7 Pro
    Lenovo w510
    Intel® Core™ i7-720QM (1.60GHz base; 2.80GHz Max Turbo, 6MB Cache)
    8GB (2 X 4GB) PC3-10600 DDR3 1333MHz
    NVIDIA® Quadro® FX 880M
    Intel 160gb SSD, Windows Home Server 5TB+
    Structural
    emwhite's Discipline Details
    Sales Support/CAD Monkey
    Structural
    Light gauge framing of homes.
    AutoCAD 2010
    Feb 2011
    Dallas, TX
    74
    You can use steel joists to span that distance without much issue.
    http://www.clarkwestern.com/document...ng%20Spans.pdf
    Typical residential loading is 10psf dead & 40psf live. If you plan to put any heavy tile or use concrete floor, I would use a heavier dead load and the amount to use would depend on your material selection.
    Assuming you are using 10psf dead, 40psf live load, 2' oc and clear span:
    You could use a 1200S200-97 joist (Which is a 12" x 2" x 12ga stud).
  7. #7
    Full Member
    AutoCAD LT 2012
    Aug 2011
    79
    Default Remark, some interesting stuff
    http://i-joist.org/
    Before I responded back I took a look at the information on both of these sites, I've seen the LVL beams used in some cases but not on any project I've done myself, all of these beams are new to me so I've got a lot of reading and studying to do, one thing is certain, there seems to be a cutoff on some of these beams at 24' feet, so before jumping to the next level, looks like I'm going to be shrinking that garage by 6 inches.
    Thanks for the info, some good stuff.
    James
  8. #8
    Win 7 Pro
    Lenovo w510
    Structural
    Structural
    AutoCAD 2010
    Feb 2011
    Dallas, TX
    74
    Quote Originally Posted by buildman View Post
    Before I responded back I took a look at the information on both of these sites, I've seen the LVL beams used in some cases but not on any project I've done myself, all of these beams are new to so I've got a lot of reading and studying to do, one thing is certain, there seems to be a cutoff on some of these beams at 24' feet before jumping to the next level, looks like I'm going to be shrinking that garage by 6 inches.
    James
    Typically clear span is assumed from inside to inside of bearing walls but then again you at the very limits of that member. Plus there are safety factors built in. Just some things to keep in mind.
  9. #9
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,794
    Thanks for the post emwhite, saved the *.pdf file for future reference.
    Used lots of steel beams, when structural, in BIG commercial buildings.
    "I" beams, largest I've used 48" BIG, never goin' anywhere. Of course, steel posts for vertical support.
    Thanks again for the reference material. And another reference, steel, attached.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  10. #10
    Full Member
    AutoCAD LT 2012
    Aug 2011
    79
    Quote Originally Posted by nicolas View Post
    Hi Nicolas
    Regards,
    Nicolas.
    Nicolas;
    A very nice read, I fully agree to the engineer certification, most of the suppliers of these beams have engineers and they will usually be very helpful if your buying their products.
    Thanks for posting.
    James
  1. Print Large Drawing Span Multiple Pages
    By emtffkev in forum AutoCAD Beginners' Area
    Last Post: 17th Aug 2010, 09:29 pm
  2. Window to span two different floors (levels)
    By Jonny_B in forum Architecture & ADT
    Last Post: 12th Feb 2009, 04:35 pm
  3. searching for garage plans..
    By tds73 in forum AutoCAD Beginners' Area
    Last Post: 9th Dec 2008, 09:34 pm
  4. Plot drawing to span multiple pages
    By Tuckie in forum AutoCAD General
    Last Post: 20th Jun 2007, 09:09 pm
  5. Garage door
    By jared98366 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Jan 2007, 03:27 am
