Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Full Member 19cruthik68's Avatar
    Electro/Mech
    19cruthik68's Discipline Details
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    Exclamation Problem scaling when plotting in Layout tab
    If I used millimeters as my UNITS, how can I scale them when plotting it into A1 or A0? How will I know the scale that I will use in Layout tab so that it will fit on the paper that I will used?a
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,646
    Draw your model space objects full size. Switch to a paper space layout. Create a viewport. Viewports are like windows that allow us to see the objects we created back in model space. Click on the viewport frame and go to Properties and set the viewport scale. There are at least two other ways to set the scale of a viewport. Once you have the view of your model space objects set the way you want then lock the viewport display. Viewports should be created on their own layer and the layer set to "no print". Plotting is done from the layout at a scale of 1 unit = 1mm. AutoCAD will automatically scale the objects in your viewports based on the scale assigned to them. Use the Page Setup Manager to set your printer, the orientation, and your ctb or stb.
    Electro/Mech
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    Thanks for the reply but i think i asked a wrong question.
    What I mean is, if I printed out in A0 and I want to get the dimension using the triangular scale ruler?because the engineer wants me to do that.you get what i mean? So if I scale it in A0 and i am using the units as millimeter probably it will be exactly the same if i am going to use a triangular scale ruler to measure the print out drawing. i hope you get what i mean
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,646
    It is not called a "ruler" it's called a "scale". Yes, I know what you mean. You want to print the drawing "to scale" so that you can take distances off of it directly.
    Will you be printing from model space or a paper space layout?
  5. #5
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Create a new paperspace sheet
    Page Setup -> A0 (then when printing, print this 1:1, extents, do NOT 'fit to paper')
    Setup a viewport on that sheet.
    I don't normally use mm so could be wrong, although I think your custom scale to enter in the viewport properties pane will be of the form 1/$desiredScale
    I.e. for 1:200, the custom scale when using mm as the drawing units would be 0.005.
    (now that I think of it though, 1:200 isn't a standard scale on an architectural scale ruler I don't think, only on an engineering scale ruler)
    I call it a scale ruler also myself
  6. #6
    Electro/Mech
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    Yeah, you knowq what i am trying to say....
    The toblerone-shaped scaled-ruler.. I want to print in paper space layout and put it in A0.
  7. #7
    Electro/Mech
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    Dink87522,
    I tried already the one you suggest, but it is not accurate when i measured it using the toblerone-shaped scale ruler in the printed out drawing.
  8. #8
    Civil
    Feb 2009
    2,338
    Is ii only out by a few percent when you measure it with the scale ruler? If so, I'd guess the scale is setup correctly in Autocad, you are just not printing it to scale.
    If you print 'Layout', scale 1:1 (assuming the A0 plot was defined in mm) does it work? I am assuming you are printing on an A0 sheet of paper.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,646
    Kids in grade school use rulers. Architects and engineers use scales.
  10. #10
    Electro/Mech
    Draftsman
    Electro/Mech
    AutoCAD 2012
    Sep 2011
    Doha, Qatar
    82
    no, it gives me a big difference.
  1. Layout scaling
    By Seth385 in forum AutoCAD Drawing Management & Output
    Last Post: 1st Sep 2011, 02:24 pm
  2. Scaling in Layout
    By JamesP in forum AutoCAD Beginners' Area
    Last Post: 13th Feb 2011, 09:37 pm
  3. Scaling problem in the layout
    By Clinton09 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Mar 2010, 11:02 am
  4. How I can set layout & scaling
    By akbarvp in forum AutoCAD Drawing Management & Output
    Last Post: 8th May 2009, 06:01 pm
  5. Model View To Layout View - Plotting Problem
    By xi-web in forum AutoCAD General
    Last Post: 9th May 2007, 02:28 pm
Tags for this Thread
