Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    Senior Member harilalmn's Avatar
    harilalmn's Computer Details
    Win XP
    Architectural
    harilalmn's Discipline Details
    CAD Manager
    Architectural
    AutoCAD 2010
    Aug 2010
    Bangalore, India
    115
    Question Set Z Position of all Blocks to Zero
    What is wrong in the code? I am trying to set the Z position value to zero for all the blocks in the drawing;
    Code:
    (defun c:B0()
      (setq myFilter(list (cons 0 "INSERT")))
      (setq ss (ssget "_X" myFilter))
      (setq l (sslength ss))
      (setq i 0)
      (Repeat l
        (setq blk (ssname ss i))
        (setq DXF (entget (car blk)))
        (setq IP (cadr (assoc 0 dxf)))
        (setq NewIP (subst "0" (caddr  IP) IP))
        (setq NewDXF (subst NewIP IP DXF))
        (entmod NewDXF)
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,106
    Code:
    (defun c:B0  ()
        (setq myFilter (list (cons 0 "INSERT")))
        (setq i 0)
        (Repeat l
              (setq DXF (entget blk))
              (setq IP (cdr (assoc 10 dxf)))
              (setq NewIP (subst 0.00 (caddr IP) IP))
              (setq NewDXF (subst (cons 10 NewIP) (assoc 10 dxf) DXF))
              (entmod NewDXF)
    (setq i (1+ i))
    variable i remains at 0.... "0" as string not real number...
    Among other things....
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,628
    Try this ...
    Code:
    (defun c:Test (/ ss i sset lst)
      (vl-load-com)
      (if (setq ss (ssget "_x" '((0 . "INSERT") (410 . "model"))))
          (setq sset (ssname ss (setq i (1- i))))
          (setq lst (cons (vlax-ename->vla-object sset) lst))
        (alert " << No Blocks existed in this drawing >>  ")
      (foreach ml '(1e99 -1e99)
        (mapcar (function (lambda (x)
                            (vla-move x
                                      (vlax-3d-point (list 0 0 0))
                                      (vlax-3d-point (list 0 0 ml))
                lst
    Tharwat
    - When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
    Win XP
    Architectural
    CAD Manager
    Architectural
    AutoCAD 2010
    Aug 2010
    Bangalore, India
    115
    pBe Thanks for your comment.. I now understand I should have added a (setq i (1+ i)) in the repeat loop...!!
    Thanks for the code Tharwat...!! That was much professional a solution compared to my code...!!
    Happy Happy....
  5. #5
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,106
    Code:
    (1e99 -1e99).....
    Interesting
  6. #6
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,732
    I would approach it this way:
    Code:
    (defun c:B0 ( / e i p s )
        (if (setq s (ssget "_X" '((0 . "INSERT") (-4 . "*,*,<>") (10 0.0 0.0 0.0))))
            (repeat (setq i (sslength s))
                (setq e (entget (ssname s (setq i (1- i))))
                      p (assoc 10 e)
                (entmod (subst (list 10 (cadr p) (caddr p) 0.0) p e))
    I don't see the need to move everything to 1e99 elevation and back just to set the elevation to zero
    Lee Mac Programming
    Just another Swamper
  7. #7
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,926
    Using (subst) on a point value is very dangerous
    (setq ip '(10 10 10 10))
    (subst 0 (caddr ip) ip)
    Returns -> '(0 0 0 0)
    Code:
    (defun c:iz0 (/ ss en ed in)
      (and (setq ss (ssget "X" '((0 . "INSERT"))))
           (while (setq en (ssname ss 0))
                  (setq ed (entget en)
                        in (cdr (assoc 10 ed)))
                  (entmod (subst (list 10 (car in) (cadr in) 0.0)
                                 (assoc 10 ed) ed))
                  (entupd en)
                  (ssdel en ss)))
      (prin1))
    I would think a lot more filtering would be advisable. Maybe groups 67 210 at the very least should be added.
    Also this will not move the attributes the elevation 0.
    -David
    R12 (Dos) - A2K
  8. #8
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,106
    or Ctrl+1
    Quick Select
    Position Z
  9. #9
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,628
    Quote Originally Posted by pBe View Post
    Code:
    (1e99 -1e99).....
    Interesting
    Thanks pBe .
    Quote Originally Posted by Lee Mac View Post
    Why not ?
    Would that harm or incorrect in away or another ?
    Tharwat
  10. #10
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,628
    Quote Originally Posted by harilalmn View Post
    [B]
    Happy Happy....
    You're welcome harilalmn .
    Enjoy it buddy
    Tharwat
  1. Sustain position of Annotative Blocks after a Move
    By StykFacE in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 5th Jan 2010, 05:15 pm
  2. exploding nested blocks and losing position
    By leesutto in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Dec 2009, 06:19 pm
  3. sun position
    By rookie37 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Nov 2009, 03:47 pm
  4. XREF Position
    By drayle in forum AutoCAD Beginners' Area
    Last Post: 23rd Sep 2009, 11:18 pm
  5. From dtext to a z-position
    By Veryname in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jan 2009, 07:21 pm
Tags for this Thread
