Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    Full Member Stryker1989's Avatar
    Stryker1989's Computer Details
    Windows 7 Pro
    P&ID
    Stryker1989's Discipline Details
    Apprentice Instrument Design Engineer
    P&ID
    Involved in the draughting of various instrumentation diagrams including P&ID's, Cable Diagrams, Loops Diagrams and Hook Up's among others
    AutoCAD 2000i
    Aug 2011
    Middlesbrough, UK
    49
    If you use the DIST command and pick the two ends of the line do you get 400? (assuming the line is either drawn horizontally or vertically)
  2. #12
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, W8 + W8.1 Vista
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    Quote Originally Posted by 19cruthik68 View Post
    I am sorry, the file is very big, containing many layers, and it will take an effin' hours for my effin' desktop to delete those bloody hell things.
    Try using WBLOCK and just pick your line and the dimensions. One minute and you're done
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
  3. #13
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    F8 and F3 is on
    Turn Osnaps off (F3) and see what happens.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  4. #14
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,146
    Perhaps you should be using Dimension Aligned (DAL) instead of Dimension Linear (DLI)
  1. Dimension height grayed out in Dimension Style Manager
    By eklektikus in forum AutoCAD Beginners' Area
    Last Post: 14th Oct 2010, 04:37 pm
  2. insert dimension measurment field on dimension line
    By bcastillo in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Nov 2009, 04:32 am
  3. AutoCAD 2006 - how to make dimension m and cm in one dimension style
    By sokha in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 9th Sep 2009, 08:45 am
  4. Replies: 1
    Last Post: 7th Jun 2006, 07:30 pm
  5. Dimension Architectural Units
    By Brunello19 in forum AutoCAD Drawing Management & Output
    Last Post: 17th May 2005, 02:28 pm
