Annotative Scaling
eciarletta
Hello All,
I just moved to AutoCAD 2010 and have a two part question.
I am playing around and have added a receptacle and a junction box using the electrical palette. When I change the annotative scaling only the receptacles change size and the junction boxes stay the same. While trying to get this to work the I added tags and panels the tags change size and the panels do not.
I have attached two pictures for a reference.
My ultimate goal is to use a drawing as an XREF for two others. The problem there is that when I use the XREF it keeps everything the same size except for the receptacles. I feel that these two problems are linked.
Thanks in advance for the help.
