What are you using to import the document? Are you using the Monochrome.ctb or the Grayscale.ctb? Are you using STBs?
I am having a problem plotting drawings as JPEGs. I have used the Page setup manager to select the JPEG plotter and I want to plot only in black and white. Previewing the plotted jpeg looks fine but when I then import the jpeg into a document, line elements appear in grayscale and it appears that only soem polylines appear as true black. Any suggestions ??
Welcome to the forum!
Is it possible that the gray lines are not orthogonal while the black ones are? Sometimes the dithering works that way. I'm not sure how to fix that, sorry.
breaking AutoCAD on a regular basis since 1991
A possible walk around: convert the image to black and white. If yellow lines are turned white, adjust the brightness/contrast first.
It's nice to be nice, but sometimes is nicer to be evil!.
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
I'm importing the image into Word as a jpeg. When plotting the image in Autocad, I'm using the monochrome ctb.
I've alreadt tried to plot the image as black/white (monochrome) - this has no effect on the result
I cannot duplicate your problem. What version of Word are you using? Have you tried actually printing from Word? Sounds like it could be a display problem.
Have you tried exporting a WMF file to insert into Word?
I'm using Word 2007. If I preview the JPEG in Autocad, it appears correct with black lines where there should be black lines but when I import the JPEG into Word or view it in Picture manager, most of the lines appear a sif they are gray scale - or at least not true black.
