Dynamic Block Grip Problem
breaked_burial
I have a problem with my dynamic blocks.
My dynamic block is similar to a crosshair (actually, very similiar to the AutoCAD crosshair with size 100). When i select the center of the crosshair, I want it to move in vertical and horizonal direction. I made this considering two grips in the center. It works fine on AutoCAD 2008.
The problem is that in AutoCAD 2010 it doesn't work anymore. It only moves in vertical direction. I don't know why this happen but I realized that the problem is with the grip overlap (when I isolate grips, i.e. when I don't have them overlapped, they work fine).
Can someone help me?
db-problem.dwg
Hello my friends. First of all, thanks for your quick replies.
Seems that it works in 2011 and 2008. I'll wait to see if someone can use it on 2010 because I really can't understand what is happening.
