your question is to vauge what is an average slope ? post example
I'd like to take an AutoCAD curve (polyline) & calculate the aproximate overall average slope of it. Attached is my code so far which works
Code:(defun weightedAverageSlopeOfCurve (<obj>) ;Some function variables (setq chainage 0.0 interval 0.1 tempList nil orig (list 0 0 0 ) maxIterations (fix 1e5) average 0.0) (setq startChainage (vlax-curve-getDistAtParam <obj> (vlax-curve-getStartParam <obj>)) endChainage (vlax-curve-getDistAtParam <obj> (vlax-curve-getEndParam <obj>)) ) ;Define the length of the curve (setq curveLength (- endChainage startChainage ) chainage startChainage) ;Caclulate the number of iterations (setq iterations (fix (/ curveLength interval))) ;;Take some loading off the CPU if too many iterations required. Revert to maxIterations (if (> iterations maxIterations) (setq interval (/ curveLength maxIterations) iterations maxIterations) ) (repeat iterations (setq dy/dx (vlax-curve-getFirstDeriv <obj> (vlax-curve-getParamAtDist <obj> chainage)) slope (angle orig dy/dx)) (setq average (+ average (/ slope iterations))) (setq chainage (+ chainage interval)) ) average )
Has anybody any thoughts on the methodology or suggestions for a different approach?
Hi BIGAL,
Sorry for not getting back to this sooner. I'll try and be a little clearer, average slope probably was the wrong term to use.
Taking an AutoCAD curve, in this case a polyline, I am intereseted in determining the average vector travelled going from the start point to the end point of the polyine.
My original thinking was to break the curve down into a series of segments, calculate the slope at each segment & from that calculate an overall average slope / vector travelled
Regards
Jammie
Wont the average of a arc just be the tangential slope at the mid point ?
Or even the line joining the start point to the end point
However the vectors vary along the way, they start at the start point and they arrive at the endpoint.
@BIGAL I hadn't considered that. I'll have to do a bit of testing to see how if/how I can incorporate this.
@eldon That was my thinking with vectors varing along the length of the curve. Every segment of the curve has a weighting on the overall average of the curve.
Perhaps the following could work?
Thanks for the help so farCode:1. Determine the number of curve segements (n) 2. Find the tangent @ each mid segment (m) 3. Find length of that segment (l) 4. Determine the magnitude of the vector (l*m) (s) 5. Add all the results & divide by total length of curve
Jammie
