command prompt problem
Benjo
Hi,
When i type something in the command promp like a command or a dimension, there seem to be kind of a delay/lag and i can't find what the problem could be.
Example, if i type the command "line" normaly fast without mixing letters on the keyboard it could be lnie, ilne, ect.. or just miss letters. I have to type pretty slow.
help please!
  • Replies 23
  • Benjo
    12
  • SLW210
    4
  • Jack_O'neill
    4
  • DANIEL
    2
Are you working on drawings that are saved on a network? If so, copy a drawing to your desktop and see if you get the same problem.
Yes im working on a network but i got also drawing on my desktop and i still got the problem :(
Are you perhaps running the program remotely on another machine? If so' date=' you should get your IT dept to install it locally.[/quote']
No, not running program remotely
Ok, a few basic questions are in order here.
1. Is this a new install and has done this from the start?
2. If not a new install, when did this aberration begin?
3. Have you recently added any new software (email client, browser, antivirus, etc)?
4. How long has it been since you rebooted?
5. How many other programs do you have running at the same time?
do you have any anti virus or spyware running you could try temperarily turning off? windows automatic updates can cause lags for some as well.
i got avast antivirus off and didn't change nothing
Ok' date=' a few basic questions are in order here.
5. How many other programs do you have running at the same time?[/quote']
1. No, i got autocad 2011 install since 10 months buts the problem is there since maybe 3-4 months
2. I think it all start when i added a second monitor, i dont know if that could be the problem
3. i install avast antivirus but i turn it off and nothing change
4. rebooted every day (after work)
5. 1, Mozilla Thunderbird
Have you tried removing the second monitor to see if it is?
Or change the settings to use only one monitor?
Yes, i've remove the second monitor and i still have that annoying lag/delay
The drivers are up to dates but i cannot play with the hardware acceleration, the clickable button is light grey and not clickable
You should have that option if your driver was approved or certified. That may be your problem.
