Help with annotative text
davidjb82
Hi there.
I've never really used annotative text in past versions of AutoCAD because I've always found it to be flawed, and also never really needed 2 different scales, but now I've moved on to 2011, it is much simpler to use, except for this 1 issue...
Is it possible to move each scaled text to different parts of the drawing? As an example, I have a room which text at 1:50 fits in fine, But 1:100 gets in the way of some of the equipment in there, so I would like to keep the 1:50 text in the room, and move the 1:100 to just outside. I can't work out if this is possible or not, or if I would just have to use non annotative text at 2 different scales.
Any help would be much appreciated.
Thank you
