intern2011 Posted September 21, 2011 Share Posted September 21, 2011 Hi. I want to rotate a drawing in my paper space, but without rotating it in model space. So that I still can work on it easily in model space. Thank you. Quote Link to comment Share on other sites More sharing options...
nestly Posted September 21, 2011 Share Posted September 21, 2011 I don't know much about LT, but I assume it has DVIEW. If so, you can use use DVIEW > TWist within your viewport. If you want to rotate the model but keep your crosshair orientation, use UCS > Z to rotate the UCS about the Z-axis, then use PLAN > Current (also within the viewport) Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 21, 2011 Share Posted September 21, 2011 Take a look at this re: VPROTATEASSOC.... http://www.dailyautocad.com/2009/12/vprotateassoc-system-variable.html Quote Link to comment Share on other sites More sharing options...
intern2011 Posted September 21, 2011 Author Share Posted September 21, 2011 Thank you very much. This is what I was searching for. Quote Link to comment Share on other sites More sharing options...
Organic Posted September 21, 2011 Share Posted September 21, 2011 I would reccomend MVSETUP and then follow the prompts. Quote Link to comment Share on other sites More sharing options...
rkent Posted September 21, 2011 Share Posted September 21, 2011 Why would you use Mvsetup with 2012 when you can simply rotate the viewport with vprotateassoc set to 1? Quote Link to comment Share on other sites More sharing options...
Squirltech Posted September 21, 2011 Share Posted September 21, 2011 I don't know much about LT, but I assume it has DVIEW. If so, you can use use DVIEW > TWist within your viewport. If you want to rotate the model but keep your crosshair orientation, use UCS > Z to rotate the UCS about the Z-axis, then use PLAN > Current (also within the viewport) This is the method I use the most with great results. Just sayin'. Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 21, 2011 Share Posted September 21, 2011 Each to his/her own devices. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 21, 2011 Share Posted September 21, 2011 Why would you use Mvsetup with 2012 when you can simply rotate the viewport with vprotateassoc set to 1? Been around awhile. If the view port is other than square or round, MVSETUP can be useful. >>>>I go both ways Quote Link to comment Share on other sites More sharing options...
intern2011 Posted September 22, 2011 Author Share Posted September 22, 2011 You guys are amazing. You were answering a lot of my posted questions very fast and very detailed. How are you doing this? Do you read each new thread? Thanks a lot! Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 22, 2011 Share Posted September 22, 2011 Yes, at the top left, under "Tutorials" is "New Posts". Quote Link to comment Share on other sites More sharing options...
