Results 1 to 7 of 7
Thread: WBlock
    Full Member
    AutoCAD 2010
    Jul 2011
    Ellijay, GA.
    72
    Default WBlock
    hi team
    I needed to change the size of my tree block
    this is the ?
    project manager now says that the trees in the subdivision need to have smaller diameters (10 feet instead of 15feet in diameter). I needed to know the best step on how to do this?
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    One solution is to select on one of your tree blocks, right click and pick "Select Similar" from the menu to select all the blocks with that block name, then change the X and Y scale to 2/3rds of the current value using the Properties Palette
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,591
    Another option is to run the command ._BEDIT to edit the geometry of the block itself.
    R.K. McSwain
    CAD Panacea | twitter
    Super Member Ryder76's Avatar
    Ryder76's Computer Details
    Windows 7
    Dell T7500
    See details...
    Ryder76's Discipline Details
    Electrical Designer - Oil & Gas
    See details below.
    Subsea Solutions
    AutoCAD 2010
    May 2009
    Houston, Texas
    570
    I would go with rkmcswain - that is the fastest way to change all the blocks in the drawing.
    "Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
  5. #5
    Full Member
    AutoCAD 2010
    Jul 2011
    Ellijay, GA.
    72
    Quote Originally Posted by nestly View Post
    ok, I try this an this is what show up on my
    radius 0.63
    diameter 1.25
    I'm slow on how things work in auto cad 2010
    so I still not sure is I understand.
  6. #6
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    BEDIT is short for Block Edit. You select one copy of the block you want edit. Make the required changes then save it. All instances of this block, in your drawing, are then updated as well. Simple and fast. Just do it.
  7. #7
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    I may have misunderstood. My advise was to change the blocks that were already inserted into the drawing, but if you're seeing a radius and diameter, then it appears you're either directly editing the block, or the block has been exploded.
    Here's a short demo showing both methods, scaling them with the Properties Palette, and using the block editor (BEDIT) http://www.screencast.com/t/JfkTHy8M
    On the other hand, if you're editing a source drawing that contains your tree (block), then you'll need to reload/redefine the block in the subdivision drawing after you make changes to the source drawing, which is a different procedure. Just let us know which is the correct scenario.
  1. Block vs. wblock
    By Memnon in forum AutoCAD Beginners' Area
    Last Post: 10th Nov 2014, 04:20 pm
  2. Wblock
    By CindyLou in forum AutoCAD Drawing Management & Output
    Last Post: 16th Nov 2007, 06:24 pm
  3. Wblock
    By HAPPY HAMMER in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Nov 2007, 12:52 pm
  4. Wblock in VB
    By TroutKing in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th May 2007, 08:37 pm
  5. WBLOCK IN ADT 3.3
    By gguillory in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Feb 2005, 06:15 pm
