Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    Full Member Hogfan's Avatar
    Hogfan's Computer Details
    Windows XP Pro
    Dell Precission 470
    Xeon 3.4ghz dual processors
    3gb ram
    Samsung hd 1600jj/p
    dell
    AutoCAD 2008
    Jul 2008
    USA, Arkansas
    77
    Question Extruding Faces on Tapered Angles
    I have a arc that is about 21.5 radius and .5 in width. My problem is that it is going on a bench that i have made and the corner piece needs to be cut out and i am trying to figure how to make this line look like an actual piece. Does this make sense to anyone? i can extrude the piece to 21 inches tall, but then i need it tapered back to fit this bench were making.
    Forum Deity Jack_O'neill's Avatar
    Jack_O'neill's Computer Details
    xp
    Architectural
    Jack_O'neill's Discipline Details
    Architectural
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    AutoCAD 2010
    Sep 2008
    lost in the Arkansas wilderness
    2,146
    Not sure I'm following what you're trying to do. Is the curved bit going to be over the desk like a roll top cover or am I lost?
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
    Windows XP Pro
    Dell Precission 470
    3gb ram
    Samsung hd 1600jj/p
    dell
    AutoCAD 2008
    Jul 2008
    USA, Arkansas
    77
    Did you look at the pdf? It is going up against the back. That is what it is, a back for this bench, then they will put padding and cover it. Sorry the pics may not do it justice. i can show an overall view of the bench if that would help.
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    MEP 2013
    Sep 2010
    1,977
    I'm also having trouble visualizing the part.
  5. #5
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    Ok..duh...you said bench, and I thought "workbench". You're sitting on this, right?
  6. #6
    Windows XP Pro
    Dell Precission 470
    3gb ram
    Samsung hd 1600jj/p
    dell
    AutoCAD 2008
    Jul 2008
    USA, Arkansas
    77
    Yes this is a sitdown bench, i will try to get a plan view of this, brb.
  7. #7
    xp
    Architectural
    Architectural
    AutoCAD 2010
    Sep 2008
    2,146
    Ok...gotcha now. Couple questions...the cushions for the seat and the back in the corner, are they attached to each other or separate pieces?
  8. #8
    Windows XP Pro
    Dell Precission 470
    3gb ram
    Samsung hd 1600jj/p
    dell
    AutoCAD 2008
    Jul 2008
    USA, Arkansas
    77
    The cushion will be seperate and the back is made of benda grade plywood.
  9. #9
    Full Member
    dshowalt's Computer Details
    Windows 7 64-bit
    Intel i7
    8GB
    Nvidia
    Education
    dshowalt's Discipline Details
    Education
    Education
    Inventor 2012
    Dec 2009
    Kansas City, USA
    57
    Are you wanting to do a Profile and then a Sweep with rails
  10. #10
    Windows XP Pro
    Dell Precission 470
    3gb ram
    Samsung hd 1600jj/p
    dell
    AutoCAD 2008
    Jul 2008
    USA, Arkansas
    77
    Possibly so , this is embarrassingly over my head. If you look at the plan view of the arc, i need it to be 21.5 tall and angled back at 9 degrees also. I have never taken any AC lessons, I am self taught mostly other than what i get from here and a few other friends. Sorry i cant answer that question with a positive response. The software i use is AC based and so i usually just modify parts through the program, except the few instances like this. Thanks.
  1. Extruding faces on a 3D solid question.
    By Cerberus in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Nov 2010, 03:25 pm
  2. Tapered Cylinder
    By jaypooner in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Dec 2009, 08:13 am
  3. extruding mesh faces
    By oompa_l in forum 3D Modelling
    Last Post: 30th Aug 2009, 05:40 am
  4. EXTRUDING/MOVING MULPIPLE FACES FROM DIFFERENT OBJECTS
    By 8 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Feb 2007, 10:07 pm
  5. Tapered Cylinder
    By ZmN in forum AutoCAD Beginners' Area
    Last Post: 1st Sep 2006, 03:55 pm
