Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 38
    Super Member
    MisterJingles's Computer Details
    Windows 10 Pro 64bit
    Intel Core i7
    4.00GHz
    32GB
    GeForce GTX970
    Mechanical 2016
    Apr 2009
    South Africa
    533
    Default JOIN aint joining.
    Hi all
    Why would 2 line segments not join to one another with the JOIN command?
    I OSNAP each end but I get this ...
    "Command: _join 2 found
    0 objects joined, 2 objects discarded from the operation
    Command:
    Command: *Cancel*"
    In this instance its an arch and a line. It happens regularly.
    Thanks
    Don't forget your towel!
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,127
    You need to use the _PEDIT command. Read up on _JOIN in help.
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,214
    Could be that the objects are noncoplanar. Check their elevations.
    I have a lot of trouble with joining arcs to lines, especially when it's a straight polyline segment joining to an arc object. Something about precision, I'd guess.
    breaking AutoCAD on a regular basis since 1991
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    The endpoints of each of those objects need to be in the same location for join to work. Use pedit or blend perhaps.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  5. #5
    Super Member
    Intel Core i7
    4.00GHz
    32GB
    GeForce GTX970
    Mechanical 2016
    Apr 2009
    South Africa
    533
    CyberAngel I dont work on different elevations, glad to hear Im not the only one who has this problem though
    rkent - The end points are in the same location as Im snapping to the endpoint. In the morning I will explore the pedit function you and SLW suggest. Home time!
    Thanks guys
  6. #6
    Junior Member
    ryank7's Computer Details
    Windows 7
    Precision T3500
    Xeon 2.27
    4GB
    NVIDIA Quadro FX 580, 1GB
    AutoCAD 2011
    Sep 2011
    South Central, PA
    11
    I had this same issue and this is what worked out for me
    pedit
    m
    select the objects
    <enter>
    j
    <enter>
    <enter>
    <enter>
  7. #7
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Attach the file here that exhibits this behavior.
  8. #8
    Super Member Patrick Hughes's Avatar
    Patrick Hughes's Computer Details
    Win 7 x64
    Dell Precision T7610
    Intel Xeon E5-2630 v2 (six core)
    32 Gb
    3 Gb Nvidia Quadro K4000
    1 TB
    2x 1920x1080 Dell Ultrasharp U2312HM
    Mechanical
    Patrick Hughes's Discipline Details
    Self unemployed - Machine Design
    Mechanical
    Machine Design
    AutoCAD 2015
    May 2008
    Rockford, Illinois
    763
    Another problem can be the object's extrusion vectors - they must match. (at least in the case of trying to join 2 arcs).
    An arc can be constructed from an inverted UCS which will cause the extrusion vector mismatch.
    www.cadtempo.com
    Time tracking for AutoCAD, Inventor, Revit and other CAD programs
  9. #9
    Super Member
    Intel Core i7
    4.00GHz
    32GB
    GeForce GTX970
    Mechanical 2016
    Apr 2009
    South Africa
    533
    Ok here attached is the file.
  10. #10
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Looks like one line has an elevation of "0" and the other has an elevation of 4.8060.
    I suppose it doesn't help looking at it in plan view as the two ends appear to touch but if you switch to an SE isometric view you'll see the problem immediately.
    Even better, after switching to an isometric view do a 3D orbit.
    Credit CyberAngel with knowing the answer. Nice catch.
  1. joining a tube
    By bikoy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 8th Dec 2008, 01:29 am
  2. Joining polyline and arc
    By Barclay in forum AutoCAD Beginners' Area
    Last Post: 16th Nov 2007, 03:56 pm
  3. Joining HHS tubes in 3D
    By robbie in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Nov 2007, 12:30 am
  4. joining 3d faces
    By spyace in forum AutoCAD Beginners' Area
    Last Post: 28th Aug 2003, 09:10 pm
