jalba Posted September 27, 2011 Share Posted September 27, 2011 Hi Is it possible to enter Excel formulaes eg: =if(a1 = 0; "yes"; "no") into table cells? I tried doing it, but I only got number symbols as the result (#####). Any advice is grateful.:D Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted September 27, 2011 Share Posted September 27, 2011 As far as I know, IF is not a supported function in AutoCAD tables. More info here. Quote Link to comment Share on other sites More sharing options...
RocketSurgeon Posted September 27, 2011 Share Posted September 27, 2011 sometimes excel defaults to ###### when the number is too long for the cell. Would that be the case here? Quote Link to comment Share on other sites More sharing options...
jalba Posted September 27, 2011 Author Share Posted September 27, 2011 re: rocketlauncher.....wasn't the case here Quote Link to comment Share on other sites More sharing options...
DODGE Posted September 28, 2011 Share Posted September 28, 2011 You can set up an Excel spread sheet then import into AutoCad. You can then link it so what ever you type in the cells in Excel will go thru to AutoCad. Quote Link to comment Share on other sites More sharing options...
jalba Posted September 28, 2011 Author Share Posted September 28, 2011 May be the following attachment may give you guys a jist of I am thinking of. Drawing1 Model (1).pdf Quote Link to comment Share on other sites More sharing options...
