Results 1 to 5 of 5
    Forum Newbie
    not specified
    Mar 2006
    4
    Default Help with Tags...or?
    Can someone give me some help PLEASE....
    What I'm trying to do is create/insert a blank title block(OR?), and be able to click on it anytime and have the info in the empty spaces change as needed.
    ex. drawn by: , date: , drawing no.: , etc...
    I would like to add my name, today's date etc.....for every different layout I make......
    does anyone have an idea how to do this?
    Thanks
    Cutter
    Senior Member
    not specified
    Mar 2005
    208
    What you want to add are called attributes. They are text fields that are attached to blocks.
    Make the attributes (ATT), put them into the proper place in the title block and then make a block (B or Block). Select the title block and all the attributes.
    When you insert the (title block) block, a screen will pop up and let you input values for the attributes. You can change them anytime by double clicking on the block or using the attribute edit command (ATTEDIT).
    Note: The order in which you select the attributes for the block, will determine the order in which they appear in the pop-up window.
    If there is anything the nonconformist hates worse than a conformist,
    it's another nonconformist who doesn't conform
    to the prevailing standard of nonconformity.
    Forum Newbie
    not specified
    Mar 2006
    4
    I've added attributes to the drawing, made a block out of it and inserted it onto a layout page. when I attedit it and a screen pops up and asks for the value so i enter it, but nothing appears on the layout page.
    I'll give it another try...........maybe I'm just doing it in the wrong order
    [/img]
    Super Moderator fuccaro's Avatar
    Mechanical
    fuccaro's Discipline Details
    Mechanical eng.
    Mechanical
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,577
    Enter ATTDISP at the command line to check/change the settings.
    It's nice to be nice, but sometimes is nicer to be evil!
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  5. #5
    Forum Newbie
    not specified
    Apr 2006
    6
    Hello and thanks..because this was my problem too, but we have to do that when we save the blank title block...or we have to change in all the drawings....i hope i understood that...please answer.
    Nice site...and forgive my english
