nannu007 Posted September 28, 2011 Share Posted September 28, 2011 hello, I have 3d model which i have converted to 2D by using the command Flatten object...now i want to convert or save it in .sat format to import it to GAMBIT environment...while doinh so it is showing an error msg as No solids, regions or ShapeManager bodies selected. my file is a 2d wiremesh after converting from 3D..i have attached the converted 2d file in .dwg format... kindly advice me... thanking you 2d.dwg Quote Link to comment Share on other sites More sharing options...
SLW210 Posted September 28, 2011 Share Posted September 28, 2011 Properties indicates it is has 300 polylines, 8948 lines and 36 arcs. You will need to make them Regions to export to .sat You can export trimmed NURBS surfaces, regions, and 3D solids to an ACIS file in ASCII (SAT) format. Other objects, such as lines and arcs, are ignored. Quote Link to comment Share on other sites More sharing options...
