Results 1 to 7 of 7
    Senior Member harilalmn's Avatar
    harilalmn's Computer Details
    Win XP
    Architectural
    harilalmn's Discipline Details
    CAD Manager
    Architectural
    AutoCAD 2010
    Aug 2010
    Bangalore, India
    115
    Default Picked point while picking an entity
    Could someone tell me what I am doing wrong here?
    This routine is to repeatedly offset the picked entity with different offset values in the direction is specified. First 4-5 offsets are ok. But then it offsets a wrong entity...
    Code:
    (defun c:QO( / PickedEnt pt0 Ent OSM
    	      OffsetTowards Ang i pt2 OffsetVal)
      (setq PickedEnt (entsel "\nPick Ent:"))
      (setq pt0 (cadr PickedEnt))
      (setq Ent (car PickedEnt))
      (setq OSM (getvar "OSMODE"))
      (setvar "osmode" 0)
      (setq OffsetTowards (getpoint pt0 "\nPick direction to offset:"))
      (setq Ang (angle pt0 OffsetTowards))
      (setq i 1)
      (While (> i 0)
        (setq pt2 (polar pt0 ang 100000000))
        (setq OffsetVal (getreal "\nOffset Distance:"))
        (command "_Offset" OffsetVal Ent pt2 "")
        (setq Ent (entlast))
        (setq pt0 pt2)
        (setq i (1+ i))
    (defun *error* (errmsg)
      (princ errmsg)
      (if (not (eq OSM nil))(setvar "OSMODE" OSM))
    Harilal M. N.
    Bangalore, India.
    "Fill the brain with high thoughts, highest ideals, place them day and night before you, and out of that will come great work." - Swami Vivekananda.
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,106
    (setq pt2 (polar pt0 ang 100000000))<--you are setting a limit with this line
    I would suggest you use the first entity selected as base for every offset and record every distance you input, add the total + the new value for your OffsetVal variable, that way the direction would still be from the orginal entitiy no need to reassign value for pt2 but only increment the offset distance by total + new value and no need for entlast
    a simple code woudl be soemthing like this
    Code:
    (defun c:test (/ PickedEnt pt0 i)
      (setq pt0 ( getpoint  pt0 "\nPick direction to offset:"))
      (setq i 0)
      (while
     (setq OffsetVal (+ i OffsetVal))
         (command "_Offset" OffsetVal PickedEnt pt0 "")
         (setq i OffsetVal)
    HTH
    Win XP
    Architectural
    CAD Manager
    Architectural
    AutoCAD 2010
    Aug 2010
    Bangalore, India
    115
    Thanks pBe, I will try that..!!
    Harilal M. N.
    Bangalore, India.
    Win XP
    Architectural
    CAD Manager
    Architectural
    AutoCAD 2010
    Aug 2010
    Bangalore, India
    115
    I revised it as you adviced pBe,
    No it is working fine... Here it is..
    Code:
      (setvar "osmode" 0)
      (setq OffsetVal 0)
      (setq i 1)
      (While (> i 0)
        (setq OffsetVal (+ OffsetVal (getreal "\nOffset Distance:")))
        (setq pt2 (polar pt0 ang OffsetVal))
        (setq i (1+ i))
      (princ errmsg)
    Harilal M. N.
    Bangalore, India.
  5. #5
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,106
    Look at the sample code i posted harilalmn
  6. #6
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,732
    Another option:
    Code:
    Command: EXOFFSET
    Settings: Distance = Through,  Layer = SOURCE, Gaptype = Normal
    Specify offset distance or [Through] <Through>:
    Select object(s) to offset or [Options/Undo]:
    1 object(s) found.
    Shift+Pick for multiple; Ctrl+Pick to erase source object.
    Specify through point or [Multiple/Options/Undo]:
    Lee Mac Programming
    Just another Swamper
  7. #7
    Win XP
    Architectural
    CAD Manager
    Architectural
    AutoCAD 2010
    Aug 2010
    Bangalore, India
    115
    Thanks Lee....!!
    Harilal M. N.
    Bangalore, India.
  1. VBA - Getting an entity at a osnap point
    By Joro-- in forum .NET, ObjectARX & VBA
    Last Post: 27th Jul 2011, 04:02 am
  2. Getting cursor coordinates without picking a point
    By fonseca in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jun 2011, 05:27 am
  3. Finding a point in an Entity problem
    By Rob-GB in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Mar 2011, 06:00 pm
  4. Calculate Area by picking internal point
    By Bane in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Dec 2009, 02:38 pm
  5. Selecting Objects Versus Picking a Point
    By BIGMIKE09281946 in forum AutoCAD Beginners' Area
    Last Post: 29th Dec 2008, 08:25 pm
