Results 1 to 4 of 4
    Senior Member paisis123's Avatar
    paisis123's Computer Details
    WIN 7 PRO
    Cyperpower CUSTOM
    Gigabyte GA-870A-UD3 (Socket M2)
    AMD Phenom II X6 1055T
    8.0GB Dual-Channel DDR3
    ATI Radeon HD 6870 x2 (CROSSFIRE MODE)
    977GB GRAID SCSI Disk Device (SCSI)
    3 TB external segate drive
    3x ViewSonic VA2231w-LED
    Mechanical
    paisis123's Discipline Details
    Designer - Thermoplastic Extrusions
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    Exclamation Civil Drafting With autoCAD, help
    Hello everyone its me paisis asking another question.
    In my booklet it asks me to "draw a 144.32' segment in a counter clock wise direction. then it asks to show the delta angle, the length, and the radius of the curve."
    how do u draw it with the instructions its giving me? how do you find out the delta angle, the length, and the radius?
    this is not the only problem im facing. as there are 2 more instances where it happens.
    5905Dd01.pdf
    please look at Page 16,17. the problems im having difficult with are 4,5, and 10.
    also im still having trouble with interpolation. i called my teacher, and he gave me some pointers but im still slightly confused. i really wish i had a formula to make everything go quickly. do you guys have a solution?
    my formula for the first 90 ft contour line was x/50=1.1/4.9 equals 11.22 from the bench mark. i check with the other thread about this and it was right. but i don't remember how to add it, to form the 100' contour.
    thanks in advance for your help.
    2 projects to go and i graduate!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    That distance is measured from the benchmark in an easterly direction. It is the location of the beginning of your 90 foot contour not the 100 foot contour.
    The calculations you are doing are for the precise placement of points corresponding to a particular contour interval. I believe this drawing uses a 10' contour interval thus you'll have a 90, 100, 110, etc. contour. The points are also placed, if I am not mistaken, along the horizontal and vertical grid lines that you also had to include in the drawing.
    WIN 7 PRO
    Cyperpower CUSTOM
    Mechanical
    Mechanical
    AutoCAD 2012
    May 2011
    Atlanta, GA
    170
    K thanks for clearing the interpolation up. but can anyone help with the first part of my problem? i need to draw those line segments with the required information. but i still don't know how.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    That section of the instructions have you drawing the cul-de-sac for Ocean Avenue if I'm not mistaken.
    To draw the arc correctly you have to go back and look carefully at steps 1 and 2 on the previous page (15) for further information (hint: radius). Once both curves are constructed you can obtain most of the required information you are being asked to provide via Properties or the List command. You will have to calculate the delta angle from the info given.
  1. Civil Drafting Project
    By progman in forum Student Project Questions
    Last Post: 24th Aug 2011, 09:44 pm
  2. need help with civil drafting
    By Firligic in forum AutoCAD Beginners' Area
    Last Post: 16th Jan 2011, 02:48 am
  3. Civil Drafting Textbook
    By BIGMIKE09281946 in forum AutoCAD Beginners' Area
    Last Post: 7th Sep 2009, 04:10 am
  4. What about a civil drafting section?
    By chulse in forum Feedback
    Last Post: 15th Mar 2008, 12:55 am
  5. Civil Drafting Standards
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jan 2006, 03:31 am
