sbush Posted October 3, 2011 Share Posted October 3, 2011 Hi, my name is Sebastien, I live in Canada, Quebec. I'm new to this forum. I am using autocad since 2007 version and today I installed 2012 version on my new computer. I noticed a problem I never had before : When I select an object (circle, line, square,... ) I can't see the properties of the object, the information stay the same like there is no selection. Very strange !! Is someone can tell me what to do ? Is there something in the Option for that ? I hope it's not a bug in my Autocad version and the problem can be solve. Thank you in advance for your answer. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted October 3, 2011 Share Posted October 3, 2011 Try setting Pickfirst=1 and see if that helps. (Options > Selection > Noun/Verb...) Quote Link to comment Share on other sites More sharing options...
sbush Posted October 3, 2011 Author Share Posted October 3, 2011 No it doesn't help, Pickfirst is already set to 1 Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 3, 2011 Share Posted October 3, 2011 Ctrl Shift P or Properties Attach file here that exhibits this behavior. Quote Link to comment Share on other sites More sharing options...
sbush Posted October 3, 2011 Author Share Posted October 3, 2011 Like you'll see in the picture, the circle is selected but nothing happen in the properties tool and quick properties Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 3, 2011 Share Posted October 3, 2011 You forgot to attach the dwg file here. Are you using AutoCAD Mechanical? What does List return? Quote Link to comment Share on other sites More sharing options...
sbush Posted October 4, 2011 Author Share Posted October 4, 2011 I re-installed the software and it's working fine now. Thank you for your help Quote Link to comment Share on other sites More sharing options...
