+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Forum Newbie
    Using
    AutoCAD 2012
    Join Date
    Oct 2011
    Posts
    2
    Default AutoCad Snap to Endpoint Issues
    Ok, so I am enrolled in an Intro to AutoCAD class, and I am stuck on one of the examples from the "AutoCAD 2012 Tutorial First Level: 2D Fundamentals" book. The example includes making a "Sensor Mount." I need to use Tangent, tangent, radius option to create a circle tangent to one circle, and tangent to the end point of another line. The problem is that whenever I click snap to endpoint, then click the end point of the line, it gives me an error in the command prompt and makes me select a new point. I tried just clicking on the endpoint without snapping it, but that made it so the circle was tangent to the WHOLE line, not just the end point. If someone has the book, it is page 2-31, exercise number 4. Again, it is called the "Sensor Mount." Any help would be appreciated guys!
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,721
    Default
    What error are you seeing?
    I just tested this in my version of 2012 and it worked fine.
  3. #3
    Super Member CyberAngel's Avatar
    Computer Details
    CyberAngel's Computer Details
    Operating System:
    Windows 10
    Discipline
    Architectural
    CyberAngel's Discipline Details
    Occupation
    Civil Drafter
    Discipline
    Architectural
    Details
    Roofing and Waterproofing
    Using
    AutoCAD 2014
    Join Date
    Jul 2006
    Location
    Anywhere Else
    Posts
    1,177
    Default
    How do you make a circle tangent to a point?
    breaking AutoCAD on a regular basis since 1991
  4. #4
    Forum Newbie
    Using
    AutoCAD 2012
    Join Date
    Oct 2011
    Posts
    2
    Default
    I am trying to make a tangent tangent circle tangent to one circle and tangent to the end point of a line. I have no idea of another way to make the circle touch the line at the exact end point and nothing else on the line. I click on the snap to end point then click on the line while in the tangent tangent radius option and the command prompt says "Specify point on object for first tangent of circle: _endp of
    *Requires a TAN object-snap and selection of Circle, Arc, or Line."
  5. #5
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,725
    Default
    Quote Originally Posted by jackallen12 View Post
    What part of that is confusing?
    Certified SolidWorks Professional
    Autodesk Inventor 2015 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
  6. #6
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,725
    Default
    ...make the circle touch the line at the exact end point and nothing else on the line
    Tangent is tangent.
    If it doesn't touch at the exact end point - then the line (or something else, like the location or size of the first circle) isn't correct. Trim it to the tangent.
    Attach your file here if you can't figure it out.
Similar Threads
  1. Select an Endpoint
    By Small Fish in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Sep 2010, 08:38 pm
  2. Autocad 2010 won't grab endpoint of polyline splined with pedit
    By incarnate in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 19th Aug 2010, 01:56 pm
  3. How to move the endpoint of a line
    By cercapatch in forum AutoCAD General
    Last Post: 11th May 2010, 09:04 am
  4. Snap Mode and Object Snap Time Line
    By AQucsaiJr in forum AutoCAD General
    Last Post: 16th Jan 2010, 09:17 am
  5. Endpoint values.
    By cordgrass in forum Map 3D
    Last Post: 12th Aug 2009, 09:15 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
