Efeezy Posted October 3, 2011 Share Posted October 3, 2011 I don't know how to make a custom button and tool bar for my lisps in Autocad 2011. It used to be easy in 2000-2005... Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 4, 2011 Share Posted October 4, 2011 It still is but use partial menus and just MENULOAD one example looking for more ***MENUGROUP=ALANSTOOLBAR ***TOOLBARS **ALANSTOOLS ID_TbModify [_Toolbar("Alans", _Right, _Show, 0, 0, 1)] AECC_ShowTS [_Button("Show Toolspace", RCDATA_16_IMAGE, RCDATA_16_IMAGE)]^C^C^C^P_ShowTS ID_Matchprop [_Button("Match Properties", RCDATA_16_MATCH, RCDATA_16_MATCH)]^C^C_matchprop ID_Erase [_Button("Erase", RCDATA_16_ERASE, RCDATA_32_ERASE)]^C^C_erase ID_Copy [_Button("Copy", RCDATA_16_COPYOB, RCDATA_32_COPYOB)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_copy,^C^C_copy) ID_Mirror [_Button("Mirror", RCDATA_16_MIRROR, RCDATA_32_MIRROR)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_mirror,^C^C_mirror) ID_Offset [_Button("Offset", RCDATA_16_OFFSET, RCDATA_32_OFFSET)]^C^C_offset ID_Array [_Button("Array...", RCDATA_16_ARRREC, RCDATA_32_ARRREC)]^C^C_array ID_Move [_Button("Move", RCDATA_16_MOVE, RCDATA_32_MOVE)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_move,^C^C_move) ID_Rotate [_Button("Rotate", RCDATA_16_ROTATE, RCDATA_32_ROTATE)]$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,4),GRIP),_rotate,^C^C_rotate) some custom stuff Alloff [_Button("All Off","Alloff.BMP","alloff.BMP")]^c^c^c(setq surface "_COGG All Off")(load "vercheck")(load "listselect")(load "changecontours6") 50mm [_Button("50mm cont","50mm.BMP","50mm.BMP")]^c^c^c(setq surface "_COGG NS 0.05 Contours")(load "vercheck")(load "listselect")(load "changecontours6") 100mm [_Button("100mm cont","100mm.BMP","100mm.BMP")]^c^c^c(setq surface "_COGG NS 0.1 Contours")(load "vercheck")(load "listselect")(load "changecontours6") 200mm [_Button("200mm cont","200mm.BMP","200mm.BMP")]^c^c^c(setq surface "_COGG NS 0.2 Contours")(load "vercheck")(load "listselect")(load "changecontours6") 500mm [_Button("0.50m cont","500mm.BMP","500mm.BMP")]^c^c^c(setq surface "_COGG NS 0.5m Contours")(load "vercheck")(load "listselect")(load "changecontours6") 1m [_Button("1m cont","1m.BMP","1m.BMP")]^c^c^c(setq surface "_COGG NS 1m Contours" )(load "vercheck")(load "listselect")(load "changecontours6") Triangles [_Button("Triangles","TRI.BMP","TRI.BMP")]^c^c^c(setq surface "_COGG NS Triangles" )(load "vercheck")(load "listselect")(load "changecontours6") Quote Link to comment Share on other sites More sharing options...
