Results 1 to 8 of 8
    Forum Newbie
    AutoCAD LT 2012
    Oct 2011
    1
    Default generate part-list/order-list in autocad 2011LT
    Hi.
    I have some blocks (different exit signs) in a drawing. I want to make a table or excel sheet that sums up the number of equal blocks in the drawing. How can i make this?
    I want to connect this tabel to excel 2010.
    I use AutoCad LT 2012, can some noe help me?
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    I don't believe LT has this capability. With a full version of AutoCAD, you have the Data Extraction tool that does this very easily and efficiently. There are also free custom LISP routines floating around (on this forum in fact) that do this as well. You'll have to upgrade, or have another version of full in your office to perform this task.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    There used to be a product called AutoTable that would provide an interface between LT and Excel. Don't know if it is still available.
    Wait a minute. Come to think of it doesn't LT 2012 support tables and data links?
    From the User's Guide for 2011:
    http://docs.autodesk.com/ACDLT/2011/...e63e479e2-7f04
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    According to THIS 2012LT has Tables and Data Links and Extract Attributes to a Text File.
  5. #5
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    Hmmm, weird, in the PDF it says no, but on the web page it says yes.
  6. #6
    Forum Newbie
    AutoCAD 2010
    Aug 2011
    7
    Data extraction, i made a dynamic bloc, A, B, C & mass all variable. I used data extraction and created an xls and a table in autocad.
    How come the table does not update when i change the dimension?
    I dont think its possible from my attempts, but, can i export the data to an existing part list template? From what i saw, you can import cells from an existing part list but not the opposite. ex: already have a Dim A in part list, cell F33, i want to export my A dimension of the block underneath that row.
  7. #7
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,135
    I think you're wanting more than Data Extraction can handle. You're probably going to need a custom programmer to write something up for you. That would be my best guess anyways. And there might be something that exists already that is floating around the internet to be honest.
  8. #8
    Forum Newbie
    Mechanical 2009
    Jul 2012
    1
    You may make the task possible by using the options available in the Excel. The options such as Draw Table or Insert table etc., can be used to create a simplified and more easily understandable approach of the exit signs. There are many other features such as colouring, editing and various other options for our designing. Please produce some attachments for the more detailed view.
    fire exit signs
  1. have an Assemble part in part list - Publisher
    By alijahed in forum Autodesk Inventor
    Last Post: 4th Oct 2011, 08:38 am
  2. How do I generate a scene object list
    By I AM CHUPA in forum CAD Management
    Last Post: 15th Jul 2011, 04:57 pm
  3. Noob Need Help - Can generate Bill of Materials List?
    By MrRee in forum AutoCAD Beginners' Area
    Last Post: 20th Jul 2009, 11:28 am
  4. Insert drawing in autocad when you have part list
    By shamsam1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Sep 2008, 05:43 am
  5. Generate a drawing from a list of coordinates
    By braedan51 in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jul 2006, 09:41 pm
Tags for this Thread
