Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: mvparts
    Senior Member
    NH3man!'s Computer Details
    Windows 7 x64
    Dell Precision M6600
    Intel Core i7-2960XM 2.70 GHz
    16.0 GB
    NVIDIA Quadro FX 3700M
    500 Gb SSD
    2-Acer B273HU
    AutoCAD 2012
    Mar 2006
    175
    Default mvparts
    I have a ton of blocks (solid objects) that I have made in vanilla Cad. We are now moving to MEP and I would like to make these into mvparts. I have read for days now and searched everywhere I can think of and can't find a place that can beat this into my head. If anyone has the time or a guide that is better than what I have found please shoot me a line. I am a converted pipe fitter so the terminology of what I have been reading need some translation.
    Thanks NH3man!
    Senior Member
    Windows 7 x64
    16.0 GB
    500 Gb SSD
    2-Acer B273HU
    AutoCAD 2012
    Mar 2006
    175
    Don't know how this got here but if it could be moved to MEP. Thanks
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,106
    I would say it got here because you created here. Just a WAG.
    Moved to MEP for you.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,488
    Quote Originally Posted by NH3man! View Post
    Thanks NH3man!
    Here's a quick run-through: http://www.geniusoftllc.com/mvparts/create.asp
    Also, you ought to purchase this book, the references in here are exactly what you need. I cannot express enough how critical this book can be in learning AutoCAD MEP effectively. http://www.amazon.com/Aubin-Academy-...7990281&sr=1-1
    Also note, I've long since used AutoCAD MEP, and now that I'm using Revit MEP more, I'm realizing how much better Revit MEP is. Don't exclude Revit. You have a long journey ahead of you (trust me I've been there) and if you ever adopt Revit MEP you'll wonder how you ever made it with AutoCAD MEP. This is strictly if you're modelling fully in 3D, for BIM related purposes, that is.
    *EDIT*
    Also note, AutoCAD MEP recently had the MVPARTCONVERT command added, for quick MvPart creation. It is not to be used for cataloging parts as it is simply a quick alternative.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  5. #5
    Senior Member
    Windows 7 x64
    16.0 GB
    500 Gb SSD
    2-Acer B273HU
    AutoCAD 2012
    Mar 2006
    175
    Quote Originally Posted by StykFacE View Post
    Yes we are also moving into Revit also. Are you breaking Revit down to frabrication drawing or just using it to model with? So far we are planning on modeling with Revit and then converting to MEP so that we can detail out fab drawing. If there is an easier way I am open to suggestions.
    Thanks
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,488
    You can make shop drawings with Revit. You can also make fabrication drawings too, but it'll require even more meticulous front end work of setup. I wouldn't convert anything, just stick with Revit. If you are wanting to really use a full model to produce fab drawings, Revit gives you an immense amount of flexibility for annotating every single piece of the entire mechanical system, since "Views" in Revit are far more dynamic and capable than AutoCAD MEP's version of "Views" could ever dream of being.
    Just remember, when Autodesk acquired Revit in 1998, AutoCAD Architecture and MEP (Previously ADT and ABS) stole the intuitive engineering that fuels Revit. The problem is, you can't recreate the ingenuity Revit has, because then you basically recreated Revit. Revit MEP does everything AutoCAD MEP does, only way better. It might not seem like that at first, as most AutoCAD users freak out when they begin using Revit and think it's worthless. Just keep all this in mind is all I'm saying.
  7. #7
    Senior Member
    Windows 7 x64
    16.0 GB
    500 Gb SSD
    2-Acer B273HU
    AutoCAD 2012
    Mar 2006
    175
    Just one more thing! I was told that Revit is not as precise as AutoCad. I would find that hard to believe just because is still computer aided. Some of our detail gets down to 1/64" not much as most is 1/16". Can this be done in Revit? Right now that is the only reason we are going with AutoCad MEP.
    Thanks again.
  8. #8
    Senior Member
    Windows 7 x64
    16.0 GB
    500 Gb SSD
    2-Acer B273HU
    AutoCAD 2012
    Mar 2006
    175
    Ok, just figured out how to create mvpart from one of my strainers. But I would like MEP to know it is supposed to put a flange on the strainer before it draws pipe and also insert flanges when I place the strainer into a run of pipe.
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,488
    Thanks again.
    AutoCAD is the most precise CAD software available as far as I know. Revit isn't used for machine drafting, so there's not a use for accuracy of that level. Lots of people have used this as an "excuse" to not use Revit but it's irrelevant. You can set the tolerance to 1/256" anyways which is more than enough precision in the mechanical world, or anything else related to the building industry.
  10. #10
    Super Member dumfatnhappy's Avatar
    dumfatnhappy's Computer Details
    Windows 7 64 bit
    3.6 dual quad core
    24 gig
    Quadro FX 1700
    269?
    twin 24" flat panels
    Mechanical
    dumfatnhappy's Discipline Details
    mechanical design (Petro-Chem)
    Mechanical
    Process piping (3D)
    MEP 2013
    Oct 2007
    Apollo Beach, Fla
    659
    hey Styk, I'm curious about your thoughts on Revit as it pertains to industry, I was under the impression that Revit was primarily for vertical projects (high rise, hotel, condos, etc) because I'm in water/wastewater and process design and I think MEP is far more powerfull especially with the content they added in 09. I mean I've been in MEP for 4+ yrs and STILL feel like I have barely scratched the surface of it's potential.
    dum
    'Suppose you were an idiot. And suppose you were a member of Congress.. But I repeat myself.'
    --Mark Twain
  1. MvParts
    By idllc in forum MEP
    Last Post: 22nd Mar 2011, 02:10 pm
  2. Annotative mvparts?
    By samthearcher in forum MEP
    Last Post: 18th Jun 2010, 02:49 am
  3. MVparts for MEP ?
    By S.P.I in forum MEP
    Last Post: 5th Aug 2008, 10:49 pm
