Results 1 to 7 of 7
    Super Member Bill Tillman's Avatar
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    Default Change Path to XREF
    I have a drawing which has a reference to an external drawing in it for the company logo which is used in the title block. We have moved the location of the company logo to a new drive and thus I need to modify the properties of the path. But when I open up the properties on this it does not allow me to change the path. I found the only way around this was to delete it and start over using the new path but I have to believe I missed something in changing the path.
    It's deja vu, all over again.
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Did you try changing it throguh the external references manager? Is the field/button greyed out or does it just not update?
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    Here is a screen shot of the XREF Property I want to change. The option to change the path is not available. That is I cannot select the text in the Saved Path field to change it.
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    You need to scroll down farther in the details section or lengthen the dialog box. Hit the elipses (...) at the end of the "Found At" row to browse to new location.
    Drafting is a breeze.
  5. #5
    AutoCAD 2018
    Oct 2008
    Miami, FL
    1,299
    I see said the blind man....many thanks for that information.
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    LOL. Yeah that one got me, too when I first starting using that dialog box.
  7. #7
    Civil
    Feb 2009
    2,338
    Lol, I was thinking you meant that it was greyed out, not that you just couldn't find the option...
  1. Change Xref path ways
    By buttler15 in forum AutoCAD General
    Last Post: 27th Aug 2010, 11:13 pm
  2. Change Xref path to relative
    By e.mounir in forum AutoCAD Beginners' Area
    Last Post: 4th Nov 2008, 02:47 pm
  3. xref path
    By diarmuid in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Nov 2006, 02:25 pm
  4. BATCH CHANGE FULL PATH TO RELATIVE PATH
    By beth in forum AutoCAD General
    Last Post: 21st Jun 2006, 02:38 am
  5. Xref Path
    By wherestheanykey in forum AutoCAD Drawing Management & Output
    Last Post: 5th Mar 2006, 09:10 pm
