mdd Posted October 12, 2011 Share Posted October 12, 2011 I'm trying to add dimensions to my 3d drawing and can get it to work sometimes and sometimes I can't. I attempt to do a dimension from the base of a pole to a ground anchor 32' away. I receive the following message: Oblique, non-uniformly scaled objects were ignored. Specify dimension lin locaiton or {Mtext/Text/Angle} I belive it has something to do with getting the UCS set up correctly, I've re-oriented my UCS several time and get no dimensions. Any info would be greatly appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
rkent Posted October 12, 2011 Share Posted October 12, 2011 I doubt that error message has to do with the UCS alignment. Are you picking two points using osnaps to pick them? To set up the UCS for dimensions in 3D use the UCS 3point option. The trick is to select the first point to the left of where the dim text will be, next select the direction for the dim line which is the X axis for the UCS, finally select the Y axis in the direction you want the dim extension line to align to. See attached. 3D dimensioning.pdf Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 12, 2011 Share Posted October 12, 2011 The base of the pole and the ground anchor are at the same elevation? Quote Link to comment Share on other sites More sharing options...
mdd Posted October 12, 2011 Author Share Posted October 12, 2011 The pdf was very helpful, thanks. I am dimensioning in 3d like a champ! Quote Link to comment Share on other sites More sharing options...
rkent Posted October 12, 2011 Share Posted October 12, 2011 I am glad to hear that it helped. Quote Link to comment Share on other sites More sharing options...
