Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Junior Member Wonder-Man's Avatar
    AutoCAD 2009
    Oct 2011
    12
    Default Feet Plus Inch Calculator
    Hi All
    I'm look for a macro or lips to create Feet-Inch calculator (specially adding feet-inch to feet-inch and other math operations). working in architectural design requires in many occasions adding and subtraction feet-inch calculations
    Thanks
    Full Member digger's Avatar
    digger's Computer Details
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    N/A
    not applicable
    Sep 2010
    N/A
    47
    This is an excellent feet/inch calculator program but it is not free.
    I'd bet that LeeMac could make one just as good during his lunch break.
    http://www.jobbercalculator.com/downloads.htm
    “Absence of evidence is not evidence of absence.” - Dr. Carl Sagan
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,816
    Use the distof function to convert everything to decimal, perform the arithmetic, then use the rtos function to convert back to feet/inches.
    Quick example:
    Code:
    (defun c:add ( / _getnumber tot num )
        (defun _getnumber ( msg / str num )
            (while (not (or (eq "" (setq str (getstring t msg))) (setq num (distof str))))
                (princ "\nPlease enter a number.")
            num
        (if (setq tot (_getnumber "\nSpecify Amount: "))
            (while (setq num (_getnumber "\nSpecify Amount to Add <Exit>: "))
                (princ (strcat "Total: " (rtos (setq tot (+ num tot)))))
    Lee Mac Programming
    Just another Swamper
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,471
    Or just buy the right calculator (since you'll be doing this addition quite often).
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,471
  6. #6
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,199
    Have you decided which log-in you wanted to keep?
  7. #7
    Senior Member troggarf's Avatar
    troggarf's Computer Details
    Windows 7
    Toshiba Satellite L675
    AutoCAD 2012
    Oct 2010
    Littleton, Co
    133
    Enter QC in the command line to open the "Quick Calculator"
    Make sure that your units are set in your drawing accordingly...
    The trick for using fractional inches that I have found is to use the minus sign as a spacer between the whole inch and the fractional inch:
    2 1/2" = 2-1/2"
    Others have had success using a regular space, but I find using the minus sign works...
    ~Greg B
    Have fun!! www
  8. #8
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,581
    I have one of these, but the more expensive one for the Pipe Fitting trade. Same company. I love it, and it goes with me everywhere my laptop goes.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  9. #9
    AutoCAD 2009
    Oct 2011
    12
    Default Keep Wonder-Man
    Keep wonder-man
  10. #10
    AutoCAD 2009
    Oct 2011
    12
    Is it so complicated to be written in Lisp and Dcl files?
  1. script possible for feet inch text?
    By vipulgos in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Oct 2011, 01:57 pm
  2. Free Android feet and inches calculator
    By BDrafter in forum Design Software
    Last Post: 20th Sep 2011, 02:32 pm
  3. Displaying Decimal Feet -- Entering Feet and Inches
    By Ethos Erlanger in forum AutoCAD General
    Last Post: 31st May 2011, 09:36 pm
  4. drawing in feet rather then inches and fractions of a inch.
    By lortech in forum AutoCAD Beginners' Area
    Last Post: 4th Jun 2010, 06:46 pm
  5. mm 2 inch
    By vinod in forum AutoCAD Drawing Management & Output
    Last Post: 24th Aug 2007, 02:37 am
Tags for this Thread
