Nobody know anything? How about a way to make a multipage dwf from seperate dwf files? Does any know if this is possible? I would be greatfull for any advise or sugestions or just a point in the direction I should go.![]()
Does anyone know what i need to have to batchplot individual dwf files and have the option of setting what the page size and %scale
The only way I've found to add sheets to a dwf sheet set is through the use of Autodesk's dwf composer.
http://usa.autodesk.com/adsk/servlet...112&id=5207220
"Work Smart, Not Hard"
Click to View My Portfolio ( Updated 05/21/2013 ) ---> http://www.rdeweese.com/
Thanks for the replieIll give it a try.
There is a free app to merge single DWFs into one multiple-page DWF, although it runs REALLY slow:
http://autodesk.blogs.com/between_th...multiple_.html
As for batch plotting DWFs, I have found Cymmetry's AutoVUE program to work quite well (and quite fast). The only problem I have had with AutoVUE is printing DWFs that contain imbedded images (the original ACAD with TIFs and/or CALs), though since we rarely have drawings such as this, it hasnt been too bad a problem.
Printers we plot to: OCE TDS600, various Xerox and HP laser printers
For 2004 and up: PUBLISH
Try this two software, they are free
one is:
http://projectpoint.buzzsaw.com/cons...1.8.zip?public
another is:
http://www.awpsoft.com/qd_plotDWF.htm
