Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
Thread: Creating arc
    Forum Newbie
    AutoCAD 2006
    Oct 2011
    5
    Default Creating arc
    Hello everyone. newbie here. i need some help. i'm quite new to AutoCAD. Currently using AutoCAD 2006. refer to above pic how to create those arc. i've been trying using the arc command, but this exercise says the arcs is create using fillet & offset comm..TQ
    Senior Member
    danellis's Computer Details
    Windows 7
    Dell Precision T1650
    Architecture 2014
    Dec 2010
    308
    Taking arc A first: Your desired radius is 58 units. Offset each of the two circles you're connecting by 58. Draw a new circle, of radius 58, at the intersection of the two new circles. Delete the offset circles and trim the R58 circle to tidy up.
    For arc B you essentially take the same process, the difference being that one of the elements you're filleting is a line. Ensure your line extends beyond the likely centrelpoint of the fillet circle. I'd have it touching the right-hand cirlce (with R52). Offset your line and circle by 45 units (the desired fillet radius). Draw a new circle of radius 45 centred on the intersection of the new line and circle. Trim to tidy.
    dJE
    Junior Member
    AutoCAD 2012
    Sep 2011
    Leeds, West Yorkshire
    16
    Or simple option is to: Having already drawn the 52dia. circle and the 40dia. circle and they are in the correct positions, just use fillet.
    F = fillet on command line, enter radius of 58 and select the two circles which are to be joined.
    Now i'm using ACAD 2010 at the moment so not sure if this still works in 2006. Give it a try
    Just drawn it on 2010 and worked fine.
    Junior Member
    AutoCAD 2012
    Sep 2011
    16
    Also, where did you get this image from? I'm creating some help vids for people like yourself for drawing simple things like this. This drawing should take about 10 mins to draw at the most.
  5. #5
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    I am not sure why you are trying to use arcs when the instructions say use Fillet and Offset commands.
    Arc A is a simple fillet between the two circles.
    Arc B is a fillet between a line, offset 45 from the centre line, and the circle. You may have to trim the horizontal line at the left hand side. You could also draw a line directly from the Quadrant node, but then you would not be using the Offset command.
  6. #6
    Junior Member
    AutoCAD 2012
    Sep 2011
    16
    Agreed Eldon, otherwise you never learn to use the different commands available!!
  7. #7
    Senior Member
    Windows 7
    Architecture 2014
    Dec 2010
    308
    I did not know you could fillet to an entire circle like that!
    dJE
  8. #8
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Why has no one mentioned the Tan-Tan-Radius option of the Circle command?
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,105
    Because that would be cheating.
    The object of the exercise was to use the Fillet and Offset commands, and in fact they do a better job than using the Tan-Tan-Radius because there is no trimming.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Depends on the exact wording of the assignment.
  1. Creating DTM
    By Burton Ngoma in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Aug 2011, 05:02 pm
  2. Creating New CUI
    By happyunited in forum AutoCAD General
    Last Post: 1st Oct 2008, 04:42 pm
  3. creating a web
    By Crompton in forum Autodesk Inventor
    Last Post: 5th Jul 2008, 10:10 pm
  4. Creating TBlock/Creating reference pathway
    By driftingsun3 in forum AutoCAD General
    Last Post: 27th Jan 2008, 08:23 pm
  5. creating VP
    By alijahed in forum AutoCAD General
    Last Post: 16th Nov 2007, 05:44 am
