Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Creating arc
  1. #11
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    Moved to Student Project Questions Sub-Forum.
  2. #12
    Forum Newbie
    AutoCAD 2006
    Oct 2011
    5
    Quote Originally Posted by danellis View Post
    Taking arc A first: Your desired radius is 58 units. Offset each of the two circles you're connecting by 58. Draw a new circle, of radius 58, at the intersection of the two new circles. Delete the offset circles and trim the R58 circle to tidy up.
    For arc B you essentially take the same process, the difference being that one of the elements you're filleting is a line. Ensure your line extends beyond the likely centrelpoint of the fillet circle. I'd have it touching the right-hand cirlce (with R52). Offset your line and circle by 45 units (the desired fillet radius). Draw a new circle of radius 45 centred on the intersection of the new line and circle. Trim to tidy.
    dJE
    TQ danellis. work great. now i been able to draw that.
  3. #13
    Forum Newbie
    AutoCAD 2006
    Oct 2011
    5
    Quote Originally Posted by Andy Leach View Post
    Or simple option is to: Having already drawn the 52dia. circle and the 40dia. circle and they are in the correct positions, just use fillet.
    F = fillet on command line, enter radius of 58 and select the two circles which are to be joined.
    Now i'm using ACAD 2010 at the moment so not sure if this still works in 2006. Give it a try
    Just drawn it on 2010 and worked fine.
    TQ. this is the best solution. very simple. gr8!
  4. #14
    Forum Newbie
    AutoCAD 2006
    Oct 2011
    5
    Hi everyone. other problems. need help of creating 2 arcs below.TQ
    A: arc between circle & horizontal line
    B: arc between 2 vertical lines
  5. #15
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Both problems can be addressed in a similar fashion. Create construction geometry (circles, offsets, etc.) and use the appropriate intersections.
  6. #16
    Forum Newbie
    AutoCAD 2006
    Oct 2011
    5
    Tqvm seant :d
  1. Creating DTM
    By Burton Ngoma in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Aug 2011, 05:02 pm
  2. Creating New CUI
    By happyunited in forum AutoCAD General
    Last Post: 1st Oct 2008, 04:42 pm
  3. creating a web
    By Crompton in forum Autodesk Inventor
    Last Post: 5th Jul 2008, 10:10 pm
  4. Creating TBlock/Creating reference pathway
    By driftingsun3 in forum AutoCAD General
    Last Post: 27th Jan 2008, 08:23 pm
  5. creating VP
    By alijahed in forum AutoCAD General
    Last Post: 16th Nov 2007, 05:44 am
