+ Reply to Thread
Results 1 to 6 of 6
  1. #1
    Full Member
    Using
    Civil 3D 2011
    Join Date
    Aug 2011
    Posts
    99
    Default Inserting Multiple Blocks AND Redefine
    I am attempting to update a numerous amount of blocks in an older drawing. Doing this one at a time is time consuming. I have done some research and found a few LSP that do insert multiple blocks, BUT they seem to not redefine the block definition.
    Here is the code that I have that I think works well except for the redefining:
    Code:
    (defun c:BlkImport (/ path LastDist gap space err newblk bname obj ll lr ur
                   InsPt dist GetFolder)
      (vl-load-com)
      (defun GetFolder ( / DirPat msg)
       (setq msg "Open a folder and click on SAVE")
       (and
        (setq DirPat (getfiled "Browse for folder" msg " " 1))
        (setq DirPat (substr DirPat 1 (- (strlen DirPat) (strlen msg))))
       DirPat
      (defun activespace (doc)
        (if (or (= acmodelspace (vla-get-activespace doc))
                (= :vlax-true (vla-get-mspace doc)))
            (vla-get-modelspace doc)
            (vla-get-paperspace doc)
      (setq gap 20) ; this is the gap between blocks
      (setq LastDist 0.0) ; this is the cumulative distance
      (if (setq Path (GetFolder))
          (setq space (activespace (vla-get-activeDocument (vlax-get-acad-object))))
          (prompt "\n***  Working, Please wait ......\n")
          (foreach bname (vl-directory-files Path "*.dwg" 1)
            ;;  OK, try & insert the Block
            (if (vl-catch-all-error-p
                  (setq err (vl-catch-all-apply
                    '(lambda () (setq newblk (vla-insertBlock space
                                    (vlax-3d-point '(0.0 0.0 0.0)) (strcat path bname) 1.0 1.0 1.0 0.0))
              ;;  Display the error message and block/file name
              (prompt (strcat "\n" bname " " (vl-catch-all-error-message err)))
              ;;  ELSE
              (progn ; INSERT was sucessful, move the block
                ;;  get bounding box
                      (setq err (vl-catch-all-apply 'vla-getboundingbox (list newblk 'll 'ur))))
                   (prompt (strcat "\nBB Error - could not move " bname "\n  " (vl-catch-all-error-message err)))
                     (setq ll (vlax-safearray->list ll)
                           ur (vlax-safearray->list ur)
                           lr (list (car ur) (cadr ll))
                           dist (distance ll lr)
                     ;;  MOVE the block
                     (setq ;InsPt  (vla-get-insertionpoint Newblk)
                           NewPt (polar '(0. 0. 0.) 0.0 (+ LastDist Gap (* dist 0.5)))
                           LastDist (+ LastDist Gap dist)
                     (vlax-put Newblk 'insertionpoint NewPt)
    (prompt "\nBlock Import Loadd, Enter BlkImport to run.")
    Anybody know how to change the code to redefine?
    Thanks!
  2. #2
    Super Member irneb's Avatar
    Computer Details
    irneb's Computer Details
    Operating System:
    Win7 Pro 64bit
    Computer:
    Antec One Hundred
    Motherboard:
    ASUS P8P67-Pro P67
    CPU:
    Intel i7 2600 @ 3.4GHz
    RAM:
    16GB-1600MHz
    Graphics:
    GeForce GT 430 (1GB)
    Primary Storage:
    Seagate1TB SATA2 - 7200rpm
    Monitor:
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Discipline
    Architectural
    irneb's Discipline Details
    Occupation
    Architectural Technician and Programmer
    Discipline
    Architectural
    Using
    AutoCAD 2013
    Join Date
    Sep 2010
    Location
    Jo'burg SA
    Posts
    1,666
    Default
    This is a pain which I absolutely hate about ACad. Even BricsCAD asks if you want to redefine nested blocks as well - so all you need do there is insert one DWG into another and answer Yes when asked.
    To get around this I made something a while back, see post #12: http://forums.augi.com/showthread.php?t=74579
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  3. #3
    Full Member
    Using
    Civil 3D 2011
    Join Date
    Aug 2011
    Posts
    99
    Default
    Is there anyway you can make that lisp run without the use of DOSlib? I cannot install programs on the work computer. IT doesnt trust me haha!
    I have also figured out a code that works for what I am trying to do. I just the folder that contains all my blocks to the support folder path, and then run this lsp:
    (command "-insert" "a=a" "0,0" "1" "" "0")
    The only thing is, I had to write the line for every block that we have (120). But now that it is done, seems to work for now. Just have to make sure "Expert" is set to 2 or higher. or else you will have the redefine dialog come up.
    Instead of doing this, it would be much more simple to select a directory that it reads from and then inserts all the blocks in that directory.
  4. #4
    Senior Member
    Using
    AutoCAD 2009
    Join Date
    Jul 2009
    Posts
    259
    Default
    Yep... I guess you will need to make your list of blocks first... and then run the routine on all the drawings you need.
    Here is another option for your list (not mine though)
    Code:
    (defun c:REDEF ()
      (setq ss (ssget "_X" '((0 . "INSERT"))))
      (setq idx (sslength ss))
      (while (>= (setq idx (1- idx)) 0)
        (setq blknm (cdr (assoc 2 (entget(ssname ss idx)))))
        (command "-insert" (strcat blknm "=C:/RYBKA_BLOCKS/BLOCKS/" blknm))
        (command)
      (PRINC)
    Quote Originally Posted by Bill_Myron View Post
    Code:
      (vl-load-com)
       (and
       DirPat
              ;;  ELSE
                ;;  get bounding box
                     ;;  MOVE the block
    Thanks!
  5. #5
    Luminous Being dbroada's Avatar
    Computer Details
    dbroada's Computer Details
    Operating System:
    XP Pro
    Computer:
    Dell
    CPU:
    Intel Xeon 2.13GHz
    RAM:
    2GB
    Graphics:
    NVIDA Quadro FX 580
    Monitor:
    DELL 23" & SAMSUNG 21"
    Discipline
    Electro/Mech
    dbroada's Discipline Details
    Occupation
    Design Engineer
    Discipline
    Electro/Mech
    Using
    Electrical 2013
    Join Date
    Nov 2005
    Location
    Sussex, UK
    Posts
    5,118
    Default
    for something as simple as that we used to go to DOS and get a listing of all the dwg files sent to a text file (dir *.dwg /b > list.txt). Open that in excel and add a column for each "command" and finally save the file as a .scr script file. When in AutoCAD you can open that file which will run it as a script.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  6. #6
    Full Member
    Using
    Civil 3D 2011
    Join Date
    Aug 2011
    Posts
    99
    Default
    So after hours of fudging around, I have found a lsp that will insert blocks and redefine them.
    The only thing is, the program brings up a dialog to search for a directory.
    I would like to hard code the directory in. is there any way to do this?
    Code:
    (defun c:IB2 (/ ocmd DirPath DwgList DiaRtn tmpList tmpName)
    (setq ocmd (getvar "cmdecho"))
    (setvar "cmdecho" 0)
    (if
     (and
      (setq DirPath (Directory-Dia "Select directory of drawing files/"))
      (setq DwgList (vl-directory-files DirPath "*.dwg" 1))
      (setq DwgList (vl-sort DwgList '(lambda (a b) (< (strcase a) (strcase b)))))
      (setq DiaRtn (MultiSelect DwgList "Select toggle to add all." T))
      (if (/= (car DiaRtn) T)
        (foreach Num DiaRtn
         (setq tmpList (cons (nth Num DwgList) tmpList))
        (setq DwgList tmpList)
       T
     (foreach BlkName DwgList
      (if (tblsearch "Block" (setq tmpName (vl-filename-base BlkName)))
        (command "_.insert" (strcat tmpName "=" DirPath BlkName))
        (command)
        (command "_.insert" (strcat DirPath BlkName))
        (command)
    (setvar "cmdecho" ocmd)
    (defun Directory-Dia ( Message / sh folder folderobject result)
    ;; By Tony Tanzillo
    ;; Modified by Tim Willey
      (vl-load-com)
      (setq sh
         (vla-getInterfaceObject
            "Shell.Application"
      (setq folder
         (vlax-invoke-method
             sh
             'BrowseForFolder
             (vla-get-HWND (vlax-get-Acad-Object))
             Message
             0
      (vlax-release-object sh)
      (if folder
            (setq folderobject
               (vlax-get-property folder 'Self)
            (setq result
               (vlax-get-property FolderObject 'Path)
            (vlax-release-object folder)
            (vlax-release-object FolderObject)
            (if (/= (substr result (strlen result)) "\\")
              (setq result (strcat result "\\"))
              result
    (defun MultiSelect (Listof Message Toggle / DiaLoad tmpStr tmpTog tmpList)
    (setq DiaLoad (load_dialog "MyDialogs.dcl"))
    (if (new_dialog "MultiSelect" DiaLOad)
      (start_list "listbox" 3)
      (mapcar 'add_list Listof)
      (end_list)
      (if Message
       (set_tile "text1" Message)
      (if (not Toggle)
       (mode_tile "toggle1" 1)
      (mode_tile "listbox" 2)
      (action_tile "accept"
       "(progn
        (setq tmpStr (get_tile \"listbox\"))
        (if Toggle
         (setq tmpTog (get_tile \"toggle1\"))
        (done_dialog 1)
      (action_tile "cancel" "(done_dialog 0)")
      (if (= (start_dialog) 1)
        (setq tmpList (read (strcat "(" tmpStr ")")))
        (if (= tmpTog "1")
         (cons T tmpList)
         tmpList
Similar Threads
  1. Auto lisp to redefine/insert multiple blocks w/o prompts??
    By Michael83 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st May 2013, 07:55 pm
  2. Inserting multiple blocks w/ a coordinates list.
    By ScribbleJ in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Jan 2013, 03:28 pm
  3. redefine multiple block definitions in a drawing
    By jurgen wuytack in forum AutoCAD General
    Last Post: 31st Dec 2010, 12:29 pm
  4. redefine blocks
    By daisenson in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Oct 2010, 07:16 pm
  5. Inserting Multiple Blocks
    By Lee Mac in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Aug 2008, 06:53 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
