2010 Autocad crashes when plotting! help!!!!
ED RDNZ
Hi readers... I'm using autocad 2010. I don't understand what causes the program to crash every single time i try to convert my dwg into a pdf (this is the plotting part for me). It simply shows my a "no responding" message on the top bar of the window and freezes. Then i have to kill the program and get upset! Really annoying!!!
Any ideas? Glad to hear them...
AutoCAD 2010? Have you downloaded and installed all updates?
You might try using a different program such as CutePDF and see if you get the same results.
What are you using to create the pdf? If its the dwg to pdf. pc3' date=' your pc3 file may have gotten corrupted someway.[/quote']
Thanks for the reply. Ive always used pc6.
CutePDF is an add-on for the cad? Or a separate app?
I had the same problem the other day.
Just one layout tab though.
Have you tried an Audit?
Now that you mention AUDIT, another problem i have is after cutting an object and then paste... Cad says "no responding". Have to wait for a couple of minutes then gets back on track...
What are the rest of the specs on your computer?
Are you on a network?
Hp Pavilon windows 7 dual core (top of my mind). Not in a network.
Could you spare a little more detail like how much RAM and what you are using for a graphics card or chip? Let's not treat this like a trip to the dentist OK?
You never told us if your software is current with all updates. I'm referring to AutoCAD not Windows.
Is this a 64-bit computer? What about AutoCAD? Is it 64-bit?
ok.... it's a HP dv7-3060us windows 7 home premium. AMD turion II ultra dual core mobile M600 2.40 ghz; 4gb RAM, 64 bit. CAD current with all updates. using a graphics card. hope i'm covering everything.
