Results 1 to 4 of 4
    Junior Member
    AutoCAD 2002
    Jul 2011
    10
    Default LISP Routine Error for AutoCAD 2012
    My office is trying to transition from AutoCAD 2002 to AutoCAD 2012. We have an Autolisp that we put in our start-up suite that allows us to run some custom commands, like doors, windows, etc... I have put the lisp routine in the start-up suite like normal, but when I open CAD 2012 I get an error in the command line. The error is, ; error: LOAD failed: "stat". I have also attached the LISP that we use. Is there any way to get this to work or am I up s**t creek without my paddle. I would like to thank you in advance for any and all help.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,084
    I got this
    Code:
    Command: appload
    bcad2002.lsp successfully loaded.
    Command: ; error: LOAD failed: "door"
    Command:
    Command: reseterr
    #<SUBR @174af44c *ERROR*>
    Junior Member
    AutoCAD 2002
    Jul 2011
    10
    I should have started with that I am new to LISP routines. With that said, I have no idea what you just posted sorry. Also, I should have mentioned this but it looks like the LISP that I am having problems with loads alot of other LISP routines as well. I don't know if that is the problem. I am really just looking for some guidance on this situation. Thank you for the help.
    Senior Member ketxu's Avatar
    ketxu's Computer Details
    Sorry, my English not well :(
    AutoCAD 2007
    Sep 2010
    204
    Function "LOAD" require file name to load.
    In your lisp :
    ;; Load BCAD Tools
    (load "door")
    (load "window")
    So you must have those file (door, window ...) with vlx,fas,lsp extension in support path of CAD. If not, it'll give you an error
  1. AutoCAD 2012 Mac: AutoCAD Error Aborting
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 5th Oct 2011, 12:30 pm
  2. Replies: 0
    Last Post: 20th Jul 2011, 12:40 pm
  3. Area Lisp Routine error in Autocad 2011 and Win 7 64bit
    By Davidg1230 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Mar 2011, 02:39 am
  4. I have an error message using NUMINC Lisp routine
    By Croftyno1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Feb 2011, 10:53 pm
  5. LISP routine throws error except when loaded from VLISP
    By walton10 in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Nov 2010, 06:18 pm
