Not sure if there is a question in there somewhere, but I have moved your thread to a more appropriate area of the forum. The Sketchup section.
I now understand why shortcut keys on using sketchUP should be properly organized and remembered... it would really make ur work faster if you have an assigned shortcut keys for each commands that u can easily memorized...
"Work Smart, Not Hard"
Click to View My Portfolio ( Updated 05/21/2013 ) ---> http://www.rdeweese.com/
yes sure, I just want to know if somebody is doing same as me...making personal shortcuts.. I am new to sketchup rendering using vray..
I use keyboard shortcuts for my most used commands (line, select, move, measure, etc...).
Eric Lay
Visit my Blog - View my Portfolio - Revit - SketchUp - Autocad - Photoshop - Twilight Render - Thea Render
I started doing this along time ago when autodesk started changing the shortcut key strokes for commands used on a routine basis, such as SA for saveas, but now, 15 some odd years later i regret this because now i have to go and modify my crap everytime i do a new install, not that big a deal really but i've been using them for so long so consistantly that they are instinct, now I try modifying as little as possible in an attempt to adapt to what ever autodesks sillyness throws at me in such regards. If that all makes sense ......
If you would like to help my 2 year old niece Alaina in her battle against Leukemia you can donate blood at any Carter Blood Care and put SPON050875 on the donor form. Thank you so much for any contributions in this matter that you can make.
Luminous beings are we, not this crude matter.
i did add shortcuts on SU but now i'm running out of keys in my keyboard hehehehe
Quote by George (AWDC Malta President) about Land Rovers:
"Trid ittiha xebgħa mazza ta' bla raġuni"
Translation: You have to attack it with a mallet for no reason at all"
