Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Junior Member
    Inventor 2011
    Nov 2011
    15
    Default Another sheet metal unfold problem!
    Hi all!
    I'm excited I found cadtutor and this is my first post. Over the years Ive used cnczone but the autodesk forum seems to be dead unless you need a autocad to gcode macro. Can't even upload a .ipt extension. I'm a newbie to inventor 2011. I've used autocad almost daily since 2005. I am seeing a need for me to move onto the paramatric modeling side of cad.
    Please remember that i'm very new to this and i know that i'm am probably doing this backwards. I drew this part in an assembly by extruding the base then extruding the sides with notches to fit around tubing that is the assembly. I was thinking that i could just take that part, convert to sm then unfold for a flat pattern. So you know where i'm going? I can't unfold it.
    I did go into the sm defaults and set my material thickness. Still not sure if i did that right also.
    What would the proper way be to create a sm part like this?
    I also have included the assembly file that the part was created in.
    Thank you for the help.
    Bear
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    755
    First rule in uploading assemblies is include the part files...
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
    Junior Member
    Inventor 2011
    Nov 2011
    15
    Parts are all drawn in assembly. I haven't saved parts individually out of assembly. The part file that is there is the first one i started working on. Like I said I'm new at this trying to train myself. So please explain!
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,007
    There are no bends in your part?
    Sketch1 has too more dimensions than required.
    Sketch2 is unconstrained.
    Sketch3 is not needed.
    You might read this document while I work up a solution to your part.
    http://home.pct.edu/~jmather/skillsusa%20university.pdf
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,007
    These are the only dimensions needed to fully constrain this area of the sketch (use Symmetry, Equal =, Coincident constraints).
    Did you intend this .015 offset?
    Is your design intent for the blue arc to also be offset .015 bigger than the green projected circle?
  6. #6
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,007
    These are some "oddball" angles.
    Are these really what you want?
    Is width and height the controlling design intent dimensions or the angles?
  7. #7
    Junior Member
    Inventor 2011
    Nov 2011
    15
    Thank you Dr.Mather.
    Dimensions in Sketch 1 where done with Auto Dimension button. I seem to have problems finding the missing dimensions to fully constrain sketches sometimes. I have since constrained sketch 2.
  8. #8
    Junior Member
    Inventor 2011
    Nov 2011
    15
    Quote Originally Posted by JD Mather View Post
    No I didn't intend for the .015 offset. How did you get that dimension. I just tried to find the .015 and i cant get it to show.
    Design intent is for the for blue arc to be same as projected circle.
    Can i see a pic of the contraints you used?
  9. #9
    Junior Member
    Inventor 2011
    Nov 2011
    15
    Yes, the width and height are controlling those angles. I also don't like it when "oddball angles, lengths, etc." are used.
    One thing that I've been thinking was, could i have just drawn the face and converted that to sheet metal? Then used the sheet metal tools to create the flanges? After that project the cuts from the tubing to the flanges?
  10. #10
    Junior Member
    Inventor 2011
    Nov 2011
    15
    Quote Originally Posted by bearracecars View Post
    Never mind, I just found it. Its the bottom to center of circle. Didn't intend for it, but its a non issue with final outcome of part. Its going to be plasma cut when finished. So tolerances will only be as good as that anyway.
  1. Problem Making Sheet Metal Flat Pettern in Inventor 2010
    By foxthegreat in forum Autodesk Inventor
    Last Post: 28th Jul 2011, 05:17 pm
  2. How to do this on Sheet Metal
    By CAnnondale in forum Autodesk Inventor
    Last Post: 17th Feb 2011, 12:49 pm
  3. how to use sheet metal, or another solution to a problem
    By gargoyle27 in forum Autodesk Inventor
    Last Post: 14th Oct 2010, 11:25 pm
  4. sheet metal. how to?
    By pinco pallino in forum Autodesk Inventor
    Last Post: 28th Apr 2010, 09:57 pm
  5. Problem with Sheet Metal Bends
    By reggy in forum SolidWorks
    Last Post: 18th Nov 2007, 01:01 am
