Results 1 to 6 of 6
    Full Member harley558's Avatar
    Inventor 2010
    Mar 2010
    88
    Default Layers or Layer States
    The drawings I generate serve 2 purposes. One is for manufacturer (which has a good bit of dimensioning detail) the other is for our customer (which has a minimum amount of dimensioning detail). My issue is that one of our facilities has asked that we try to supply both types of drawings for them. Is there a way to do this on just one page. Either by freezing layers or creating a layer state, i.e. Manufacturer, and have all the shop details within that state. Can you actually have 2 states within a drawing and freeze or turn off one?
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    976
    The simple way is to use two layers for dimensions. The first layer would have the customer's dimensions, and the second layer would have the manufacturer's. Turn on the second layer, you have the manufacturer's plan--turn it off, you have the customer's.
    breaking AutoCAD on a regular basis since 1991
    Inventor 2010
    Mar 2010
    88
    That is one way we have thought of but the only issue I see with that is that there are a few of us that use POWER DIMENSION to dimension drawings which automatically puts the dimensions in the AM_5 layer. With it doing this that would mean you would have to go through and change some layers on the dimensions for this to work. Unless there is a way of doing POWER DIMENSION and it putting the dimension in the layer you need it when you create it.
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,125
    Is this an AutoCAD question? POWER DIMENSION sounds like Mechanical.
  5. #5
    Inventor 2010
    Mar 2010
    88
    I apologize it is Mechinal Desktop 2004.
  6. #6
    Inventor 2010
    Mar 2010
    88
    Can anyone out there clarify a good method using POWER DIMENSION.
  1. Unwanted layers & Layer (Mgr.) states from other drawings
    By Cad Monkey 2 in forum AutoCAD General
    Last Post: 11th May 2011, 11:24 pm
  2. importing layer states makes some layers disappear!
    By Kincaid in forum AutoCAD Beginners' Area
    Last Post: 21st Jan 2011, 09:41 pm
  3. Autocad LT 2009: X-ref layer states / Layer states manager
    By Mako in forum AutoCAD Drawing Management & Output
    Last Post: 6th Nov 2008, 04:24 pm
  4. saving layers states with lisp
    By copernico84 in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Apr 2008, 01:56 pm
  5. Layer states
    By youflyifix in forum AutoCAD General
    Last Post: 3rd Mar 2006, 12:56 am
