KSher55 Posted November 7, 2011 Share Posted November 7, 2011 So apparently pickfirst doesn't have any hold over my clipboard commands. I'm trying to select a group of objects, and use Ctrl+C to copy that selected group of objects between files, however autocad is deselecting the group of objects at the start of the command. I have double checked pickfirst and it IS set to 1. Commands like move, or copy behave normally and listen to pickfirst. The copyclip command does not. Any help? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted November 7, 2011 Share Posted November 7, 2011 Try _PICKADD = 1 or 2 Quote Link to comment Share on other sites More sharing options...
KSher55 Posted November 7, 2011 Author Share Posted November 7, 2011 Thanks for the tip, unfortunately no cigar Quote Link to comment Share on other sites More sharing options...
nannerdw Posted November 17, 2011 Share Posted November 17, 2011 Try QAFLAGS = 0 Quote Link to comment Share on other sites More sharing options...
KSher55 Posted November 18, 2011 Author Share Posted November 18, 2011 Try QAFLAGS = 0 Thank you! That works perfectly! Case closed! Quote Link to comment Share on other sites More sharing options...
TheyCallMeJohn Posted February 9, 2012 Share Posted February 9, 2012 Thankfully this fixed my problem. I really enjoy how this AutoCAD command is still active and can change my settings even though Autodesk list this command.: "Undocumented Command or System Variable". ...Someone needs to invent a sarcasm font. Quote Link to comment Share on other sites More sharing options...
